I take on my Hymer 660 heater...
Discussion in 'Tech/Mech General' started by JJ, Nov 10, 2010.
  1. JJ
    JJ Funster
    May 1, 2008
    14,899
    26,720
    Sleeves rolled up and, screwdriver in hand, I tackle my Truma heater in the Hymer.
    Last season it would only ignite randomly and as the winter approaches here in Portugal I am reluctant to use the van without the heater 100%.
    I have a new igniter/gas switch unit and a new (double) burner ready to go in.
    Yesterday I investigated and removed bits and now just have to undo the gas pipe and she should come out...
    ...more later...
    JJ
    PS... Any information from experienced Truma Funsters welcome...
  2. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    Hope all goes well, and remember the soapy water:thumb:
  3. hilldweller
    Dec 5, 2008
    27,554
    26,665
    Macclesfield
    And no crap like "Are you a qualified gas fitter with C651/23 and G665/A/JJ/F554 certificates. If not you really should not be messing with GAS. Have you not seen the news, half of Irlam was destroyed, 200 houses, by a gas leak".
  4. JJ
    JJ Funster
    May 1, 2008
    14,899
    26,720
    started an apprenticeship in Irlam (Royles)... I bet the fitter on that job had all the certificates...
    I have "grandfather rights" certificates...
    JJ
    PS... I went up a ladder yesterday without a trained and qualified ladder holder at the bottom of it...
  5. hilldweller
    Dec 5, 2008
    27,554
    26,665
    Macclesfield
    Hell of a guy.
    Respect.
  6. JJ
    JJ Funster
    May 1, 2008
    14,899
    26,720
    I win... the heater loses...
    It tried to stay where it was but, after patient and skillful application of a little muscle, out she came...
    Following this triumph there are those who would have got stuck straight in, replaced the suspected faulty part and finished the job...
    ...but not me!
    Coffee time and post this news... then it will be too late to continue today so I will continue in due course... like tomorrow... maybe.
    JJ :Cool:
  7. hilldweller
    Dec 5, 2008
    27,554
    26,665
    Macclesfield
    It's a Truma Jim, but not as we know it.
    Ours is round !
  8. JJ
    JJ Funster
    May 1, 2008
    14,899
    26,720
    bet yours is one of those young, whipper snapper Combi 6 water and space heater all in one thingies...
    ... mine is a stately 22 years old and while it is being fixed/serviced I could still have hot water should I choose...
    JJ :thumb:
  9. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    Go for it JJ, I have every confidence in you, considering its 20 years old, from the photo it looks quite unused.
    Doug...
  10. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,396
    5,423
    East Sussex 01-580-881288
    JJ,
    Don't use a match to test for gas leaks
    BOOM BOOM
    :Rofl1::Rofl1::Rofl1::Rofl1:
  11. JJ
    JJ Funster
    May 1, 2008
    14,899
    26,720
    A match... do you think I am some sort of backward idiot?
    I will use a lighter...:Rofl1: :Rofl1: :Rofl1:
    JJ
  12. Douglas
    Aug 22, 2008
    2,837
    401
    South Wales,
    I always thought it was cowboy caravan technicians that did that! every body else used manometers
    Doug...
  13. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    go for it live the life and never do today what you can put off until tomorrow, after all who knows tomorrow may never come.
  14. John & Joan
    John & Joan Funster
    Mar 30, 2010
    1,299
    710
    Full Time on the road
    Back or Front heater JJ?
    We replaced the front Truma e2800 with an e4000 after water ingress through the outside wall vent. There is no drain for it to escape.
    Had the burners replaced in the rear e3000 earlier this year. The bigest problem we have had with the back one was with the battery box and its wiring. Van is 1992 Hymer S700 so only 18 years old.
  15. JJ
    JJ Funster
    May 1, 2008
    14,899
    26,720
    Hi John and Joan,
    My Truma doesn't fit to an outside wall... it is a double heater, it looks like two joined together and came out as one unit... its air intake is through the floor and the burnt gases are vented via a flexible chimney through the roof. The ignition system together with the flame cut off system is on the front heater so is easily accessible when the heater is in place.
    It is all fitted with German thoroughness, clips holding everything firmly in place, the bits of wood that had to be removed to get the heater out are all machine cut and fit perfectly and are held in place by many screws. Very reassuring...
    JJ :thumb:
  16. John & Joan
    John & Joan Funster
    Mar 30, 2010
    1,299
    710
    OK JJ
    It is an e5000 the double version of the e3000. I have the original German manual for the e3000/5000 if you need any info.
  17. JJ
    JJ Funster
    May 1, 2008
    14,899
    26,720
    you are very kind John (Joan?)... I too have an original manual (operating manual)... yours isn't a service manual as well is it?
    JJ
  18. John & Joan
    John & Joan Funster
    Mar 30, 2010
    1,299
    710
    Sorry JJ only installation and information. They are quite straight forward I have worked on the old SB1800 a number of times, which is the same principle. The little nuts can get siezed but WD40 works well.
  19. JJ
    JJ Funster
    May 1, 2008
    14,899
    26,720
    Bad News
    the igniter part is not quite the correct one... the gas supply pipe is different... can't fit it...:cry: :cry: :cry:
    The Good News
    I have found the fault... a tiny earth wire had slipped out of its screw down connecter (hence the initial random nature of the fault). I have refitted th earth wire and the igniter is sparking like a firework...
    :thumb: :thumb: :thumb:
    JJ
    PS... anyone want to buy some Truma heater parts... brand new?
  20. JJ
    JJ Funster
    May 1, 2008
    14,899
    26,720
    Heater now fitted back in and running like a dream...
    No soapy bubbles from the joint... :Smile:
    Nearly beer time...
    JJ :thumb: :thumb: :thumb:
