I love my new motor home! (1 Viewer)
Gwyn
5
Brighton
Talbot swift Capri
I'm a newbie
Hello everybody,
I recently bought myself a 1993 Talbot Swift Capri 540gxl and am really chuffed with it.
I took it from Brighton to South Hams last weekend for it's first outing and it performed very nicely, lots of fun.
The only problem was that the carver water (which was working last week) would'nt light. The gas bottle was full, the gas lines were turned on, it was full of water, there was power to the control unit and I could hear the ignition clicking but no joy, just very cold showers!
Anyone got any ideas? Would be very much appreciated.
Also the main blow heater in the cab seems to have packed up, the fan works but no heat so cold drive home.
Many thanks
Dec 6, 2011
11,593
25,426
South Wales
Coach built Adria
hi welcome, whenever i had that problem with my last motorhome heater / boiler it was usually i had not taken the cover off the flue or the flue was blocked. just a stab in the dark:thumb:
Apr 12, 2012
240
97
Fleet, UK
Pilote Atlantis 34
MoHoing since 09/04/12
Congratulations on your new purchase! I've had my first one for just over a month now. Been out for one full weekend away, and am having much fun sorting out those little niggles that come with owning an older van ::bigsmile:
Everyone on here has been very helpful with advice!
I'm sure you'll have loads of fun with it!
:welcomefunster:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Have you changed bottles since it last worked Air in gas lines maybe.
Cab heater,Control cable broken or loose or hot/cold flap inop or stuck,
Thermostat stuck open or missing, over cooling ???
G
Gwyn
5
Brighton
Talbot swift Capri
I'm a newbie
Thanks guys,
I'm going to have a look later and see if I can ascertain whether these might be possible causes. I did change the gas bottle, if air has got in the line for the water heater do I clear it by keeping trying to light it or is there another way?
Thanks for all your suggestions
Philb
36
5
Carmarthen Wales
Low Profile
Newbie
Have you got gas at all, ie the hobs? If not check the motion sensor button near to the gas regulator. Just press it in..
Jan 4, 2012
2,242
2,023
somerset
Fiat Ducato
A few years now
Well done on your new motor home---i bet you wish you bought one years ago ?
I do :thumb:
G
Gwyn
5
Brighton
Talbot swift Capri
I'm a newbie
I've wanted one for the last 10 years so it's a dream finally realised for me.
There is gas coming out of the hobs and grill, will check the motion sensor
mandymops
188
107
Streatham
bedford rascal nipper
I'm a newbie
Hi and welcome,
It's hugely exciting isn't it? I've just got my first one too and foresee a whole new life of possibilities. I'm sure my friends and family are sick of hearing about my new project but at least here,you can talk to people who are all equally crazy,(some more than others.):ROFLMAO:
TheBig1
17,630
43,326
the gas may be an air lock or a bit of grit in the jet. Try purging by several lighting attempts.
the cab heater is probably a broken clip on the control knob or just behind the dash. they tend to seize up over the years and eventually jam solid. not much else to go wrong as the heater matrix is basically a radiator run off the engines cooling system. the control operates a valve. very basic on the old vans, so parts are easy to come by on EBAY
Carol
14,051
112,118
North Wales.
Hello and welcome to motorhome fun, all these little problems that crop up now and then help us understand our vans better, and the forum is a good source of information. :welcomefunster:
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Hi and welcome :thumb:Carver- Try taking the outer cover off (4 screws) and lighting it with a taper.:thumb:It could have got damp-happened on one of mine yrs ago once warmed up/dried worked fine :thumb:
terry
G
Gwyn
5
Brighton
Talbot swift Capri
I'm a newbie
What a warm welcome! Thank you guys for all your suggestions, I'll let you know how I get on. Have got to go away for a fortnight to Ireland for work early tomorrow but I just want to tinker with my new toy!
G
Gwyn
5
Brighton
Talbot swift Capri
I'm a newbie
Simplest solution often fits
I'm sure it will come as no surprise to many of you that the problem with my carver heater was operator error.
I had turned off the gas supply to it in my cupboard by accident when packing to go away, Do'h!
Oh well, I now understand a lot more about how it works for when it really breaks down.
It does leak a bit which I assume is frost damage, is that important or easily fixed?
