Hymer with 2.8 jtd engine, ejector fault light coming on (2 Viewers)
Dergrowler
129
759
Banbury, Oxfordshire
A Class, Hymer B578
Hi all
Just recently our Hymer B644 with the 2.8 jtd engine has started to play up with the ejector warning light coming on and the van seems to go into limp mode.
Have taken it to a Fiat main dealer to have a diagnostic check carried out but as its a 2001 model the fault codes are very basic. They did come up with break lights or accelerator. As the accelerator control unit had been replaced just before we brought the van back in May they concentrated on the brake light switches which they seemed to think was a common fault, but I have not read this on any forum but seems to be common on VW transporters.
Any way they replaced my engine battery as they said it had died on them, had no problems previously myself but it could just be a coincidence. They where also not happy with the wiring saying it was below standard but I think they just wanted to wash their hands of it and not have anymore to do with the van suggesting I get an auto electrician to look at it.
I have surfed the Fiat forum and there seems to be a common problem with these 2001 model Fiats having wiring faults and possible loose connections has anyone else experienced this.
Regards
David
Apr 25, 2012
794
826
Near Truro, Cornwall
Not had warning lights coming on, but when we bought ours (a 2006 /56 plate) the tails lights played up a few times and we took it back to the dealer. he did fix it, but said the wiring behind the rear light clusters was exposed to all the muck thrown up by the rear wheels and this would cause poor connectivity. he recommended regular application of grease after reconnection. In four years I have only greased the connections once so it seems to have worked. Ours is also a 2.8jtd. Gary
Aug 18, 2014
23,797
133,854
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Yes brake light switch can bring on limp mode if it has the dual contacts. It has one set of normally open contacts for the brake lights & a second set which are normally closed that are commonly used for dropping out the cruise control
( tempomat )when you touch the brake pedal.
Another 'limp mode' problem on them was wiring to the injectors . ( not sure if it was on that year model )
Jun 17, 2012
2,934
9,935
North Essex
Autotrail Delaware
>12 but <13
A previous reply by me, may help?
Red Light
Most good independant garages will have a diagnostics machine. They won't spank you like a main stealer and you usually won't need an appointment.
Their machine (usually Snap-On) will normally pin-point the problem and they can fix it cheaper than a main stealer as well!
You can spend more money trying a fix than paying out for a diagnostic test.
I bought my MH private (2.8, 2005 Ducato) Red light came on over 2800rpm.
Diagnostics revealed turbo boost problem which translated as stuck spindle on waste gate. Fixed in 1 minute !! Vehicle had stood for several months near to the coast and spindle had seized.
Good luck
Dergrowler
Dergrowler
129
759
A Class, Hymer B578
Thanks for the replies will look at both areas and report back
I did go to an independent first Larby but unfortunately with both their snap-on and another computer system they could not communicate with the ECU that was why I went to a main dealer but I will not be going back and I am looking around for another independent who has experience with light commercials in my area.
David
2657
BIL had a 51 plate with same problem, after much searching it turned out to be the wiring to the injectors, mainly a bad connection made worse by the leads being too short. As far as I remember he eventually fixed it himself with a set of longer leads which I think are available as Fiat modification.
Reactions: f6c
Dergrowler
Dergrowler
129
759
A Class, Hymer B578
Thanks Matamors
This know fault with the injector leads keeps cropping up and my van is also on a 51 plate so I will be looking in this area as soon as the weather is dry enough
Thanks again for all the rapid replies.
David
Jan 24, 2016
20
Belfast
2001 Hymer, Ducato 2.8jtd
I too have a 51 plate 2.8jtd that goes into intermittant limp mode especially over bumpy roads. I have tried most "fixes" suggested on this site and others with varying degrees of success. Could someone please help me by saying what the specific fault code would be if indeed the injector leads are at fault. I don't want to go to the expense of fitting lead extensions if this is not the problem.
Thanks in anticipation.
John
Steve
1,613
2,062
Compton Berkshire
on and off for 40 years
had same problem, renewed wiring plug on no. 4 injector and rerouted the wires been ok for a couple of years now. But still carry a couple of spare plugs.
denisejoe
5,621
12,054
Warden isle of sheppy
wiring to injectors is a known problem Fiat deny there is a problem but made replacement sets of wiring longer. We had our replaced under warranty by Becks.
Joe
teensvan99
231
250
Margate
Try and re route injector wiring as it is very tight and with engine movement the plug connectors are strained all the time. We had this problem with our 2004 2.8 jtd. Fitted tune it box with longer cables no more faults.
