Hymer mirror needs repair (1 Viewer)
Feb 19, 2015
1,776
1,249
Norfolk
Globecar Campscout 2013
Since 2016
Unfortunately we clipped the mirror on the way back yesterday and lost the casing on the back. (And the little circular fisheye mirror)
We're going to go to Frsnce Tuesday anyway as the mirror itself is useable although the leads are visible now . Does anyone know anywhere between Calais and Riemes who might be able to fix that for us?
Jac Sprat
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
Thanksz
Are they good and not rip off merchants?
Also is it the sort of thing we have to ring ahead to order ?
Finally will we need the whole mirror replacing do you think?
I appreciate your advice
Jac Sprat
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
Jeez !!!!
I just read some threads on this and it sounds a very expensive damage.
Could we just stagger on with our damaged mirror? The actual mirror works fine, just lost little small circular one and the plastic back.
Oct 18, 2014
1,858
1,157
Salisbury
Hymer B598 PL
Since 2013
If you access the Internet, access Hymer.com and search out dealers/repairers you are near (you can then view on a map) and then I would phone around and see which one is best.
Jac Sprat
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
Do you find the fish eye circular mirror useful on the passenger side? This is what has dropped off.
Is it necessary for spotting cyclists.
Getting a bit worried now....
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I would guess the stick-on mirror was added after manufacture. Not sure what age your Hymer is but the stick-on was not fitted by Hymer so far as I am aware. Get one in any accessories shop, or you could fit a larger one on the top like I have (on both sides). If you want these, they are called Hercules and fasten to the main mirror housing with a screw clamp that is invisible once fitted.
Jac Sprat
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
Thank you
I've uploaded two pics (see thumbnails below) to show where the mirror goes and to show the lack of casing on the back.
The van is 2006 age.
It looks to me like the fisheye mirror is integral to the mirror.
JeanLuc
3,304
2,199
Warwickshire
As I thought, the stick-on circular mirror has been fitted by a previous owner. You can get similar in Halfords etc. Personally I prefer the larger wide-angle mirrors that I have fitted on top.
The main mirror casing is available - as an example below is an Ebay link (just make sure it is for the correct year). Also a link for Brownhills Ebay shop which has the 'genuine' article but is more expensive.
General link
http://www.ebay.co.uk/itm/Hymer-Mot...442323?hash=item27f6a09013:g:7H0AAOSw1vlUtjzM
Brownhills link
Broken Link Removed
And here is a link to the Hercules blind spot mirror
http://www.vancomfort.co.uk/blindspotmirrors.htm
Jul 29, 2013
9,071
18,539
Salisbury
Hymer B678DL A class
since 2011
The circular bit looks like an add on I would gaffer tape up the back and use the van till You get a replacement the wide angle mirror can be useful as there are blind spots on Motorhomes like most vehicles.
Jac Sprat
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
I think the magnum company just does UK build only ?
Also our van is late 2006 I believe and the Brownhills specify 1999-2006 only.
I will contact both though
Jul 29, 2013
9,071
18,539
Salisbury
since 2011
Hymers are built in Germany not UK but you'll get non factory spares here on ebay
Jac Sprat
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
We just ordered a pair of self adhesive Sumex blind spot 2.8 inch round mirrors from Amazon prime for £4.49!
Looks like it'll do the job nicely.
Cannot believe it is self adhesive and under a fiver !
sparky
97
85
bingley yorkshire
a class burstner aviano i
30 years
Hi I have 2 of these mirror backs brand new in boxes but one I had painted gold to match my old burstner van they are universal so will fit passenger or drivers side £40.00 for the pair plus postage
Jac Sprat
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
We don't really want a gold one though.
Appreciate the offer
sparky
97
85
bingley yorkshire
30 years
hi no problem one is black but I will sell them at peterbourgh show the gold one cost £45.00 to paint regards slan
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
Try eBay, you might get guaranteed next day delivery.
Jac Sprat
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
I'd be interested in buying the black one though of you don't mind splitting them?
Are you sure it would fit our 2006 van mirror ? I put some pics on this thread.
makems
3,440
27,701
Ingleby Barwick,,Teesside
Sadly had to give up
From your photo of the back of the mirror It is made by Mekra Lang in Germany and is identical to the ones fitted to Burstners.
I have had two mirrors broken on my Burstner so i know exactly what they look like without the back.
Just measure the height and width and check with @sparky that they are in fact the same size.
Im prepared to bet they are.
funflair
19,363
30,276
Guisborough
MORELO palace
since 2012
Worth a look here.
Broken Link Removed
Guess you wouldn't be sorted for Tuesday but worth a bookmark.
Martin
JeanLuc
3,304
2,199
Warwickshire
You may have got it sorted but in case not, this may be useful information. You state your van is late 2006 but the pictures you posted show the same mirror system as fitted between 2000-2005. Does yours have the newer tear-drop shaped headlamp units, or does it have twin Hella round lamps on each side? If the latter, then it is a 2005 model year although it may not have been registered until late 2006. If it has tear-drop shape then it is 2006 model year onwards. I thought the 2006-> models had mirrors that hang down from the top of the side screens.
Jac Sprat
Feb 19, 2015
1,776
1,249
Norfolk
Since 2016
Yes it has round headlights not tear drop shape. That's interesting info thanks.
No not sorted the mirror back yet
Hammie
467
278
Neismann & Bischoff Arto
newbie/2015
Hey thanks my mirror back is damaged too and Carlyle bus and coach is 5 miles away. Yaaay.
Hammie
467
278
newbie/2015
I tried the stick on mirrors but returned them keeping the same ones Jean-luc has, which I bought online very cheaply.
