Hymer Melting Fog Lamps (1 Viewer)
Jul 18, 2009
11,186
17,835
HYMER B644
I had recently replaced the foam insulation on the bonnet of our A - Class Hymer B644 2000 MY.
Sat in traffic in the heat, we suddenly noticed a burning smell. Panic set in and as soon as we could, I pulled over to check and found the foam to be fine. We just put it down to maybe someone burning tyres.
The other day whilst looking to see if I could fit A/C, I noticed it was the fog lamps that had melted. I must have knocked the switch.
It seems these Hella made lamps are a common failure on Hymer and London Cabs.
Not wanting the same thing to happen again. Does anyone know of an alternative replacement brand?
TM
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
I like that Idea, I guess the problem may be finding decent ones that don't have a permanent drain on the battery when turned off@!.
I don't understand the "turned off" bit. Unless you have CANBUS which could be a problem with lower wattage.
You will not get an LED as good as the original but does that matter, aren't they just for show ?
Oct 8, 2016
222
224
bognor regis
Burstner Aviano 675G
10 years
Ours melted too, it's a common problem. I just taped them up and forgot about them, don't need them anyway.
