reynardracer
Thanks Lee I will check it out tomorrow and make a decision. Many thanks for your help.
Ok so the job is done, not as easy as some might say but nine the less done. Here is a couple of tips and or issues I found.
The replacement parts bought from eBay 'onestop gearbox shop' were Ok except for the synchro hub that was a real pig to get onto the splines. It was obvious that this part was not a meticulously machined as the original and took some getting onto the splines with the use of a gently persuader. Tip here is to cable tie the synchro hub together to stop the ball bearings getting out as you tap it into place. Then cut the cable ties obviously.
We didn't drain the oil in case we couldn't get it done, but after draining the oil decided that as it all came out with the cover off we should be able to refill it through the drain hole in the bottom of the gearbox with the cover off. Yet to prove that theory.
One question, what oil is recommended for this gearbox. Can't seem to find what is brand is recommended.
Thank you to everyone who has assisted me during this time as you have all been most helpful.
Hopefully it will now just be a case of filling with oil and driving away.
Peter
