Hymer 534 rear lounge and rad filler
Discussion in 'The Beginner' started by Justavagabond, Jun 29, 2012.
  1. Justavagabond
    Justavagabond Read Only Funster
    Nov 23, 2011
    Somerset
    Hi there
    I've changed from caravans to a 1989 hymermobile on a fiat chassis, it's the one with the grey grill with 'Hymer' apertures. I have limited paperwork with the van and am restoring the 'improvements made by the previous owner. The U shaped rear seats currently have (what I assume is DIY thin plywood bases). Does anyone know what they should be like? I'm guessing slats like a caravan. Second qusetion may be daft, but the radiator header tank cap is a few mm below the underside of the soundproofed ply dash, how do you top up water? Thanks in advance for any insights.
  2. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,232
    16,833
    Liverpool.
    Cant help regarding the under bed, but the header tank is the same on all the older Fiat/Citroen/Peugeot chassis. Its a pain to see if it needs topping up and the only way I have found is by sticking your finger in when cold. The only way to top up is by a hosepipe or piece of hose attached to a watering can. I suppose if you cant live with that you could move it to a lower place.
  3. greyman1
    greyman1 Read Only Funster
    Aug 7, 2011
    363
    273
    manchester
    hi, i have a 1996 534 [the next shape] but a similar layout and the seat bases on that are only plywood and as far as i can see are totally original . the drop down table provides the strength for the bed when it is required so they dont really need to be anything more substantial . garry
  4. JJ
    JJ Funster
    May 1, 2008
    14,765
    26,361
    I believe Greyman1 is right...
    I have a 1987 Hymer... plywood seat bases... I don't think the idea of sliding out slats came until later...
    JJ :Cool:
  5. frogijock
    frogijock Funster
    Jul 3, 2008
    706
    406
    Lincolnshire
    Had a 89 hymer and the plywood bases to lounge seats is standard
