How to fix cable to the roof (11 Viewers)
Nov 7, 2015
497
469
Newport, Shropshire
Autosleeper Broadway
since 2015 previously caravaning 25 years
Hello, we've got a motorhome thats already fitted with a roof mounted setup and the cable was fixed down with self adhesive cable tie bases but afterwards a couple of years they have deteriorated and come away. I think the answer maybe to use white rectangular cable trunking and stick it down with sikaflex type sealant, what are the alternatives. ?
Any advice would be appreciated
Chris
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Go with your own thoughts :xThumb:
Personally I use self adhesive trunking and just seal the sides with sikaflex
43,339
49,540
I used a length of YT2 cable trunking to secure my solar cables as you say.
YT2 is around 20mm wide by 15mm deep.
If yours is for a sat dish cable you could use YT1....15mm by 15mm, it should easily take one sat cable.
You can buy sticky backed but still needs a line of sikaflex to be safe.
Makes a neat job
19,379
30,379
I reckon the white trunking is the way to go, it comes plain which you could stick or with a self adhesive tape the tape would my choice.
Spanner
Nov 7, 2015
497
469
Newport, Shropshire
Yes I thought about that and the UV Rays would probably not deteriorate the adhesive too bad although the sikaflex would perhaps be more permanent
43,339
49,540
I use sticky back almost every day in my job.
The tape sticks like shit to a blanket indoors on a smooth clean surface, but doesnt weather too well outdoors.
Still needs a bit of sikaflex to make it permanent.
Spanner
Nov 7, 2015
497
469
Newport, Shropshire
Ok then standard trunking, no tape to deteriorate and a nice neat line of sikaflex along the underside and seal the ends of the trunking with a splodge of sealant.
Thanks for the suggestions
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes you have the luxury of time. Just don't try putting the cables back until the adhesive as set.
On a one day job self adhesive is essential as the cables have to go in straight away to complete the task.
Jan 8, 2013
8,491
11,530
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Just bought this kit plus a reel of 4 mm solar cable for £15. I have a mate who will make me the stainless brackets FOC to mount the panels to the roof. Total outlay should be about £200 for 240 Watts of solar power.
Thanks for the heads up with the sticky backed trunking I'm going to use.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
I use 6" nails. :xThumb: The cable never moves, but you can scrape your head moving around inside.
Spanner
Nov 7, 2015
497
469
Newport, Shropshire
Simple answer is to just fix the cable with dabs of Sikoflex at regular intervals.:xThumb:
Yes I think that is the most practical method especially as the cable is routed in a curve to avoid a roof vent, thanks for the suggestion
32,673
66,650
When I put the solar panel on our roof, being a PVC using rigid trunking wasn't an option due to the undulations etc, so I placed the cable where I wanted it and used some gaffer tape strips to temporarily hold it down then with Sikaflex I stuck some cable clips over it (those used for electrical cable in a house like the below) ... mine were white and I removed the nail ... although I suspect Toots wouldn't! :rolleyes:
ae235
53,495
150,311
Same as Andy except I use silicon along the sides makes life easy if I ever need to remove it.
Although it will do the job it looks tacky and makes cleaning the roof a pain.
icantremember
8,336
17,558
Near to Watton in Norfolk
Hymer T-SL668
since 2005
It also has the advantage that water can pass under the cable so shouldn't cause puddling on the roof.
32,673
66,650
... and how many MH owners actually clean their roof ... you must be one of the few! :D
Jan 8, 2013
8,491
11,530
Burstner Lyseo 690G
And me once a year, on my hands and knees with a sponge pan cleaner. Mostly because I can see it from my bedroom window
53,495
150,311
Always give the roof a quick once over when I wash the van & at least once a year I get up on the roof and give it a thorough clean, solar panels coming off next time, a bit of green algae under them.:xlaugh::xlaugh:
CeeJay13
54
67
The North of Hampshire
Returned 2015 after many years of kids and other expenses!
Nails (6") that should do it. !!
I would do that little bit extra over @Tootles and bang the end of the nails over inside. Saves getting any bloodstains on the furniture
Sikaflex sounds good to me!
