How olds your rubber? (1 Viewer)
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Also don't just assume that Gaslow are all tested in production :roflmto:
This one leaked at the crimp straight out of the bag!
Broken Link Removed
43,330
49,446
to clear up any confusion....ed should have said REGULATOR on bottle or bulkhead....not valve.
Regulator on the bottle means gas will already be at low pressure so only needs alow pressure hose
Regulator on the bulkhead means gas between bottle and regulator is high pressure and needs a high pressure hose....once gas leaves the bulkhead regulator it only needs a low pressure hose.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Valve on bottle means gas comes out of bottle at low pressure (use rubber).
Valve fixed in locker means gas leaves bottle at high pressure (use metal).
Replace "valve" with regulator and it makes sense :winky:
DuxDeluxe
14,658
72,782
Planet Zog
A woosh bang van
since 2008
Please see second post.
I still don't understand it. My old system had flexible rubber pipes - high pressure - to the regulator and then metal pipes - low pressure - to the appliances. Of course I'm probably stupid but that is normal.
Do you mean "regulator" instead of valve?
Edit - thanks Techno - just worked it out
Minxy
32,656
66,564
E Yorks
Carthago Compactline
You can, as far as I'm aware, still get both low pressure and high pressure hoses, so the 'legal requirement' to have a SS hose for a high pressure installation smells like cow poo! ::bigsmile:
DuxDeluxe
14,658
72,782
Planet Zog
A woosh bang van
since 2008
Pricey, but I would have them every time - except for the once when apparently I didn't!:Blush:
daisy mae
675
597
Leicestershire
C class Coachbuilt
I`m a newbie, now 1 year
I had a habitation check a few months ago on my first MH which I have since sold, I had bought new rubber hoses that were date stamped, he said they were fine, he fitted those for me, no problem, seems some are out to make money .
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
Please see first post.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Pictures make a thread so here's one of my previous van a 2004 Starspirit. New owner scored there :Doh:
Trikimiki
538
1,019
Glasgow
Since 2012
Well after all this excitement I have Butane and not Propane.
Butane is stored in the bottle around 1 bar pressure, then the regulator on the neck of the cylinder reduces it to whatever pressure. Propane cylinders are filled at 9 bar pressure approx so then goes to a regulator at much higher pressures to start with, the regulator then reduces pressure as required. So I can see the reason for braided pipes to a propane regulator, why I was a bit lost as I was presuming everyone ran on Butane.
2 years in still a lot to learn. Thanks for info Andy never knew those systems existed.
wasp
1,724
18,180
Warsop
None gone caravannin
You tend to find that in winter or cold weather the butane pressure drops off but lpg retains the pressure cos it boils off at -46 degrees or thereabouts and that lpg hoses are date stamped and you get different pressure hoses also so beware:thumb::thumb::thumb:
Trikimiki
538
1,019
Glasgow
Since 2012
Just a thought overnight. Looking at this thread again some folk have rubber pipes between a propane bottle and the regulator?
Minxy
32,656
66,564
E Yorks
Yes, as I mentioned previously, the pipes come in low pressure and high pressure versions, so with a high pressure bottle you can use a rubber hose to the fixed regulator if you want, rather than go to the expense of a SS one.
Feb 4, 2010
2,329
1,590
Mid. Glamorgan, S. Wales
Motorhutch / Toy Camper
Since 2010
I presume that with a hose with this written on it:
BS 3212:1991/2/6.3 HIGH PRESSURE LPG 08/09
the 08/09 is the manufacture date (August 2009)? In which case I need to start looking for a replacement.
The 1991 had better correspond to the British Standard! :Smile:
TheBig1
17,630
43,279
these are a bargain at £10 for 2 or less if they accept an offer
Broken Link Removed
Jul 1, 2010
3,198
33,505
SW Northumberland
Hymer B 588 DL
Since September 2010
Retired marine engineer here, worked with various flexible hoses an all sorts of equipment over the years most SS to comply with various regulations. Usually the SS was in the form of external braiding for strength, heat resistance, UV protection etc to name a few and the inner tubular part rubber. What and how are SS Gaslow and the like hoses manufactured. :Doh:
TheBig1
17,630
43,279
there are 2 types, overbraided rubber and overbraided convoluted semi flexible stainless steel liner
the benefit of using full stainless is apparently the rubber reacts and leaches oily residue from the propane and blocks regulators. was never a problem for regulators on bottles or for some manufacturers bulkhead regulators. truma regulators are the most common to fail due to gumming up
Jul 1, 2010
3,198
33,505
SW Northumberland
Hymer B 588 DL
BH
Had ours fail at 11 months on first van replaced under a H & S issue by Truma. Cheers for the info Big1 :thumb:
