How much fuel can these things really use? (2 Viewers)
errpaul
538
83
Wiltshire
11 yrs
So we have just got back from a last minute trip to Disney in the van (just decided before new year...lets go tomorrow! Love having a motorhome).
Anyway, my question is does anyone know how much extra fuel can really be used running things whilst driving.
Maybe a bit sad, but we used approx 12l less diesel coming home than going! Same route, cruise control set to the same speed, approx same weight (within 70kg or so).
The only difference was we had the fridge on 12v going there, along with a habitation heater which is controlled from the cab. The fridge was on halfway home and the habitation heater occasionally on.
Could they really use this much more fuel or am I missing something??:Eeek:
I was thinking if that was the case then running fridge on gas whilst driving is a better option?
Blown air heating whilst driving would probably be better too.
Any ideas?
Cheers
aba
2,775
1,112
yorkshire
dec 2009
anything that uses engine power has the potential to use more fuel the alternator on the van just charging the engine battery will put a certain amount of load on the engine if you then run the fridge on 12v it puts around 20amps of extra load on the alternator so the engine has to work slightly harder to compensate add to that air con lights wipers heater blower and you can be up at over 100 amps fairly quickly.
also a slight hill will increase consumption as will wind.
running gas appliances when driving may be frowned upon as in the case of an accident you have a much higher chance of bursting into flames.
however there are special valves that allow you to use gas on the move which cut off the gas supply.
and before someone says about lpg cars they have safety cut offs too which is why 90% have to be started on petrol before they switch over to gas.
errpaul
errpaul
538
83
Wiltshire
11 yrs
I never realised it was so much. I know they would use a little extra, but working out the mpg there was a 20% difference!
On the subject of using gas whilst driving, is this different with the gaslow type refillable system?
Sep 26, 2013
4,170
5,156
Market Rasen
Since 2003
I think that you are right about being sad, the probable cause is likely to be the direction of the wind.
Mike
Dec 6, 2011
11,596
25,450
South Wales
Coach built Adria
check my figures but Paris to say Salisbury is around 360 mile and you used 2.6 gallons more.... so thats around 1/2 mile per gallon difference, i think!
that could be anything, from head wind / tail wind coming home.
Wind !
We've had constant strong winds lately, if you had a tail wind one way and a head wind the other -- Bingo.
It does not take a lot, just look at the difference in fuel from 60 to 70. A steady 5 mph wind would do that to you. +5 one way -5 the other.
haganap
12,760
26,462
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
absolutely what he said ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2 factors, weight and wind and Aircon, (yes thats 3)
never heard of running a fridge, lights or anything else making a difference, but I also know Abba knows his stuff so stand to be proved wrong.:thumb:
aba
2,775
1,112
yorkshire
dec 2009
to use gas on the road you need something like this.... Link Removed
callumwa
4,110
4,480
Tyne & Wear, sometimes..
Agree with the wind being the reason...
Even a slight head wind will make a noticeable effect on a motorhome..
I drove an 800 mile round trip just after New Year in the car (much more streamlined than a motorhome)..
400 miles there, 400 miles back...
Going 46.8 mpg, coming back 58.9 mpg, only difference strong SW'ly headwind on the first trip.
:thumb:
Jim
Ringleader
Jul 19, 2007
36,446
131,013
Sutton on Sea, UK
Adria Panel Van.
Since 1988
It will definitely be wind Paul, all things being equal, even if only a little is working against you it can really make a difference to you mpg
Dec 6, 2011
11,596
25,450
South Wales
Coach built Adria
check my figures but Paris to say Salisbury is around 360 mile and you used 2.6 gallons more.... so thats around 1/3 mile per gallon difference, i think!
sorry finger trouble on calculator its more like 3 mpg extra. still could be hills and wind direction
Oct 1, 2013
7,513
19,952
Lanzarote
Nil by mouth
Lots
Not sure about the fridge, but I know that air-con does decrease MPG by as much as 5% :Smile:
17,635
43,359
or more downhill than uphill on the return along with weather conditions, stop start traffic etc. 1/4 of a mile per gallon of fuel is trivial on the scale of things over all
worrying about the little things in life ends with missing the good bits in my experience
FULL TIMER
795
717
NORWICH
SELF BUILT IVECO 75E17
The heater's, assuming you are talking diesel blown air such as eberspacher only use about 300ml per hour when running flat out in boost mode dropping down to around 100ml per hour on lowest setting. I would say that your route probably has more uphill sections on the way there, other things such as wind will also effect the economy as will being stuck in traffic jams
18,034
48,139
Your fridge might be drawing about 50W of power, give or take, which is less than a tenth of a horse power. Of course your MH isn't going to be running at full power so let's assume it was producing an average of 50 bhp during the journey. That's just a guess but probably isn't far off. Now let's say you average 25 mpg at an average speed of 50 mph which means it consumed 2 gallons every hour. We can now say to produce 50 bhp for one hour takes two gallons so to produce a tenth of a horsepower for one hour will take 0.1 * 2/50 = 0.004 gallons per hour. Approximately of course as the figures are guestimates and I've ignored losses in the generation of the electrical power but essentially your fridge is running on next to no fuel.
A diesel burning habitation heater would consume a lot more but even our oil heated house only gets through something like a gallon every 24 hours even in winter.
wasp
1,724
18,180
Warsop
None gone caravannin
Is it downhill coming back ??:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO: Sorry couldn`t resist
errpaul
errpaul
538
83
Wiltshire
11 yrs
Thanks for all the replies.....wind seems to be the favoured answer then. We were battered from all directions there and back, and didn't really notice it struggling more at any time due to the wind, but then I wasn't going quickly, and cruise control would've helped.
Only reason I noticed was as it is a relatively new van for us and the first time we have taken it to France, or any distance that has required more than a tank of fuel one way.
In the grand scheme of things it's not a lot, but just thinking if I can save a tenner or more per tank by flicking a switch to a different setting on fridge for example why not. ::bigsmile:
safejourney
5
uk
Don't own one yet
Motorhome wasn't parked as flat in France so the fuel gauge showed extra in it.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
The alternator output should make no difference it is being driven by the engine continuously at whatever revs your engine is running at.
Switching on the aircon will engage the compressor which will then be driven by the engine and increase load and fuel consumption.
The weather has been circulating around UK /western europe in a anticlockwise direction making the wind S to SW so a headwind down tailwind back
18,034
48,139
Just a minor observation but cruise controls in themselves don't improve mpg although it would have reduced the variables on the journey, which I think is the point you were making mentioning it.
errpaul
errpaul
538
83
Wiltshire
11 yrs
The fuel used was measured full to full with the full ups added so worked it out that way :thumb:
That makes perfect sense with the wind then :thumb:
Yeah that was the point, so not down to any difference in driving style over the two journeys. :thumb:
11,956
16,570
On the subject of Autogas safety: there is no shut-off valve that operates as a result of an accident or collision. Output from the gas container is always limited to the max the engine can use so that in the event of a collision / ruptured line a limited-by-design amount of LPG will escape, and continue to do so. Autogas tanks also have a pressure relief valve that operates if tank pressure exceeds the design limit (in the event of a fire for example) and the outlet of this valve vents to atmosphere.
Autogas vehicles are started on petrol to force the driver to use enough petrol to keep the (petrol) system 'wet' and prevent varnish / stale petrol clogging up the EFI system. Such vehicles can be programmed to start on gas but that requires the driver to manually switch to petrol occasionally for the reasons stated.
The reason for not using LPG heaters on the move is that all domestic appliances are fed with vapour from the top of the gas container (unlike the Autogas vehicle where LPG is fed from the bottom of the tank as a liquid). Vehicle movements during normal driving can easily cause liquid LPG to be picked up by the vapour outlet of the cylinder or tank which would vapourise at the appliance causing flare and potentially a fire (think of a cold cartridge-type gas torch / blowlamp - the cheaper versions flare or spray liquid gas if they aren't held vertically until they've warmed up).
Devices are available to allow use of LPG on the move - they comprise a small container in the gas line that traps any liquid that's picked up as a result of vehicle movement & give it time to vapourise before it continues onward to the appliance (heater etc).
Aug 30, 2012
4,270
11,305
Home of the war horse
burstnar T640
Wind
We normally get 29 to gallon
On run down to bennidorm our average was 23
We are running about 200 kg heavier then normal (elaines shoes)
Wind was up and down all the way
Run over pyrenees was awfull foggy cold and windy
schojac
339
234
Cambridgeshire
new in 2009
Did you enjoy your excursion?
Then does it really matter?
I appreciate that we all have economy at heart both in maintenance and running costs but personally I just ::bigsmile: and bear it.
As long as the results are not down to mechanical/engine management then reflect on your enjoyable trip and look forward to the next one.
23,836
72,536
I would say wind as well..
BUT !!!!
We have noticed ( repeatedly ) the colder the ambient temperature the poorer the MPG.
I have checked it time and again and we always do less ( a lot less ) if the temp is low.
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Temperature alters the "Stoichiometric ratio" i.e. The mixture strength and also the burn rate due to oxygen content etc.... But,,,, it WAS the wind.. :ROFLMAO::ROFLMAO::ROFLMAO:
Oct 1, 2013
7,513
19,952
Lanzarote
Nil by mouth
Lots
An engine makes more power in cold conditions as the air is denser.
But, colder thicker air means more wind resistance.
Hmm, not sure what point I am trying to make here, so I'll be waiting over there >>> :ROFLMAO:
11,932
9,097
Not read all this thread but it could be a few more down hills going and up hills coming back -Only way to check is to do the same trip again ::bigsmile:I tend to do mileage check after filling-brim to brim never just one way :Smile:
terry
