How long is it reasonable for damp to clear after repair? (1 Viewer)
Mack100
766
2,697
Swift
When Swift engineers paid us a house call to fix the missing bolts they discovered ceiling damp. They said 17% but in fact it was closer to 27%.
Our dealer diagnosed that the roof sealing strip (see photo) was poorly applied and was letting in water.
This has been repaired and I'm now wondering just how long to give the van to dry out considering current climactic conditions. I've bought the van home and I'm considering putting on the heating to see if that will help for a couple of weeks.
How long is reasonable to assess whether the repair has been fully effective?
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
you can put the heating on, it will evaporate the moisture which will then condense everywhere there is a cold surface, windows etc. Until you can open up the van to air in a dry atmosphere I think you will be wasting your time. Sorry. The water is sitting between the roof and the ceiling it cannot escape, to dry it properly the ceiling should at least be opened up to let it breath. This is why damp is such a problem The people who fitted the bad seal should do a proper job or you are just storing problems for the future. If it is a new van or under a Swift warrenty I'd be sending it back for a proper job to be done.
Xabia
1,186
821
Rural Nottinghamshire and Spain
Since 1996
Have you got, or can you borrow, a dehumidifier, much better way to deal with the damp quickly and efficiently.
Mike
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
resealing it is fine but it needs the inside roof out to dry it out any idiot can seal in damp I would be having a word with someone if I were you
Mack100
Mack100
766
2,697
Swift
Thanks for the replies, all good points, I'm taking the motorhome back to the dealers on the 20th to have some other Swift "errors" fixed so I'll have a chat then.
Would this be a job for the dealer or Swift?
ps: still under warranty
paulmold
892
302
North Wales
7 year (25yrs a tugger)
Your purchase contract is with the dealer not the manufacturer.
Terry
11,939
9,125
Lincolnshire
Can't remember ;)
The dealer should be well capable to fix it --A case of removing a internal board and letting it dry out -AT the moment you have damp trapped between the roof and vinyl faced boards both of which are more or less waterproof (ceiling board less so) so any water in there cannot get out -a bit like those garden things in a bottle - the heat etc warms the air up and then causes condensation that runs back into your boards in what is in effect a sealed environment :Doh::Smile:-Until it's opened up it will take a very long time to dry -opened up it may well dry in a few days :Smile:- until it's opened and inspected who knows how long it's been leaking ? thus who knows how much damage? chances are it's been leaking since it was built so could well have wet lots of your van that will only show at probably the lowest point
terry
Mack100
Mack100
766
2,697
Swift
Cheers for that detailed reply Terry, if anyone knows about motorhome construction it's self-build people like you.
Mack100
Mack100
766
2,697
Swift
Having thought about this further and read the advice given in this thread I have decided to escalate the damp issue with the dealer.
This post:
Broken Link Removed
in this thread:
Broken Link Removed
Apr 18, 2009
3,569
3,367
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
Damp is every Motorhome owners worst nightmare:Sad: and it sounds like your dealers have just sealed it up without looking to see how bad it was, if it were me I'd want to know, so I think you are doing the right thing but be carefull about being fobbed off, stand firm and good luck we are right behind you:thumb:
Until you fall of course then we'll run like hell:Blush:
TheBig1
17,649
43,467
applying heat alone in a damp environment will make it worse and spread the issue. as already explained you need to get the water out of the ceiling where its trapped. it needs opening up and warm air blown in with a powerful dehumidifier in there for a minimum 48 hours
if you leave the damp sealed into the ceiling/roof it will cause the boards to start rotting.....that damp smell you get in older motorhomes that have previously leaked
Mack100
Mack100
766
2,697
Swift
Holy thread revival you may say...................................just an update....
We went into our motorhome a week ago and it smelt musty so I did a damp test with my little consumer meter
sorry for the lousy iphone pics but the results are there to see.
I had asked the dealer for a full damp test and report back in March which they did not do so having taken legal advice a strong letter has been sent to the dealer and an advisory letter to Swift.
Legal action looks likely.
The last lawyer I spoke to at Which Legal mentioned that even if the manufacturer did a full strip down repair I would be legally required to inform a future buyer of this which would impact resale value.
