how do I ..... (2 Viewers)
movan
movan
21,492
120,753
Moving around
Burstner
since07
Thank you everybody who has taken the time to post to try and help me. I will take up every suggestion given and I really appreciate it.... it can be difficult sometimes not having someone to bounce off when things seem to be going wrong. You are all amazing Funsters. Thank you again.. (PS going to Aldi Lidyl tomorrow @bigfoot ) xx
Jack Russel
43
22
Stockport
van conversion
We use a compressor fridge and diesel heating.
Our 6kg gas bottle lasts us a season. We are away at least once a month and recently had five weeks in France only using sites for eight nights.
Our next MH won't be having a gas fridge either.
Sallytrafic
93
145
Salisbury
Coachbuilt on Transit
since 1988
Hoorah for this thread I am about to go to Amsterdam and will be away about two weeks, all off ehu. So after I read this thread I casually looked when I bought the last propane: 16th May. How many days on gas (counting only ⅔ when driving for the most part) 22⅔ and then weighed my 11kG Flogas to see how much left Arghhhh 1.6kg. So just been to get a new one, thanks for saving my bacon.
Oh and my average consumption is 9.4/22.7 just over 400g per day. just my fridge and kettle and hob cooking plus two times heating up the water for showers. I think the average might be little less because we don't drive for eight hours a day and when we stop on goes the fridge and kettle so if I ignore the driving and only count half days when we start or finish it comes to 25 gas days and 375g per day.
Sallytrafic
93
145
Salisbury
since 1988
My last one had a compressor fridge and so will my next!
CWH
5,151
247,515
WildAx PVC
From November 2013
OK: Tech/mech question now. (Sorry @movan but you know how one question leads to another .....)
What's the alternative(s) to a compressor fridge and what's the difference/ pros & cons please?
EDIT - I found this so I now know how compressors work!
http://www.explainthatstuff.com/refrigerator.html
movan
movan
21,492
120,753
Moving around
Burstner
since07
I am pleased that you asked that @CWH I was wondering too.
Reactions: CWH
Sallytrafic
93
145
Salisbury
since 1988
Well your fridge at home is most probably a compressor fridge (my brother has a gas fridge but his kitchen was fitted out by the man who did Noah's Ark. ).
So instead of heating a fluid and letting it condense to produce cooling it compresses a gas and lets it expand to produce cooling.
Pros and cons of compressor fridges:
Cons: more expensive initially, makes a noise when motor running, heat at radiator more difficult to vent, must have 12V.
Pros: doesn't use up your gas, works just as well travelling as parked, more efficient, doesn't suffer gas problems like sooting up or failure of flame detection safety device, you can leave it on when on a ferry.
CWH
5,151
247,515
WildAx PVC
From November 2013
Thank you @Sallytrafic , that's really helpful (y)
Are you saying that a compressor fridge can ONLY work on electric? ("must have 12v")
10,117
18,383
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
yes compressor fridges run on 12v i cant see how they are any more or less difficult to disapate the heat than a 3 way if you use vents for both
Reactions: CWH
Puddleduck
12,386
44,004
Scottish Borders
Without at present
On and off for many years.
We do this, even though on HU, great to not waste any hot water, and ready for drinks or washing up. We have a Thermos 1.7 flask and I'm amazed for how long it keeps the water really hot.
Hope you get it sorted soon Movan. :happy:
Even do the thermos thing at home :)
As we don't drink normal tea or coffee but the herb / fruit type or hot chocolate or bovril the water in the thermos doesn't need reboiling.
17,635
43,358
there is a "very limited" way to check for a gas leak. turn off all gas appliances turn the cylinder off for 1/2 hour then listen closely as you turn back on again. a hissing sound means the pipes are re-filling, so the pressurised gas in the pipes is going somewhere. repeat the test regularly
if it sounds like you have a leak, get it tested and inspect ALL the gas pipes and connectors
11,955
16,570
A pressure test is really the only way to be certain. There are numerous joints throughout the gas pipework and leak detection spray is only useful if you have a rough idea of where to look. A pressure test is very simple to do and shouldn't be expensive. I went through all this a few years ago on my last van: increasing gas usage for months (even when parked on my drive and not in use). One day I was examining the rear tyres when I got a strong smell of gas traced to the OS rear wheel arch. Inside & above that area were the shut-off valves for the various gas services and all the pipes leaving the valves came out into the top of the wheel arch just inside the lip of the skirt. The body hole had been sealed with silicon & when I pulled it away the pipes inside it came away too - they'd all rotted inside the silicone blob. All that was left was crunchy pipe-shaped rust. Steel pipes in wheel-arch + road salt + 20-odd years of use had seen them off.
32,667
66,608
I know some have been suggesting putting the spare boiling water in a thermos of some sort but ... why not just boil enough for your immediate needs in the first place!
swanseajack13
992
2,310
Swansea
3 years
JOY . do not use soapy water on any gas pipes or fittings,from a gas safe engineer a little knowledge and bang if you can smell gas turn it off and get it checked out , you could use a match and your van would be all over wales only joking get it checked out lol still lol ray
Puddleduck
12,386
44,004
Scottish Borders
Without at present
I boil the kettle when I have free electric from the solar pv panels at home -in effect free boiling water.The hot water in the thermos can then be used later in the day when the sun is no longer strong enough to provide enough power for the kettle and I'd be buying electric from the grid :)
Sallytrafic
93
145
Salisbury
since 1988
Well the heat comes out of a chimney structure in a Absorbtion fridge (3 way) and a flat panel on a compressor fridge. For
Well it can work on what ever you use to power the motor but 12V is normal.
Reactions: CWH
Sallytrafic
93
145
Salisbury
since 1988
Should have been 'Absorption' in the above post ..... and have you noticed that fridge has a 'd' in it but refrigerator hasn't :whistle:
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
You can use the edit function for up to 60 minutes Frank
EDIT just seen you previous post was Wednesday :LOL:o_O
Scattycat
920
1,262
Mayenne, France
Rapido
Yep, the thermos thing works well. We make a pot full in the morning and it usually stays hot until the evening.
As far as gas detection goes I bought a small pen type unit off e-bay.
It only cost about £14 and well worth the money
