Hot Water Problem (2 Viewers)
normanandsue
1,871
21,571
Dunfermline - Scotland
van conversion
I need help from the technicians among us please.
I am having problems getting the full amount of hot water from my Truma water heater.
Facts - capacity of hot water heater - 12 litres (According to the manual)
Fact I am only getting 6 litres (Measured with litre jug)
Fact - I have just had the printed circuit board replaced
Fact - the hot water does not flow immediately, but is preceded by spluttering before the hot water does flow.
Fact - the system is 13 years old
My conclusion - system is furred or silted up. If so how do I de-furr it or de-silt it or is my self diagnoses way off the mark?
I would like to solve the problem before getting to Lincoln if possible.
Many thanks guys I know I will get loads of advice - most good, some humorous and some helpful if not applicable
Norman
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Spluttering sounds like the system is not bled properly... air lock...
You can get a descaler... never tried it myself..
43,331
49,461
my opinion....wrong circuit board fitted not allowing full temperature before switching off.
its the only thing thats changed.....unless its always only given 6ltrs
TheBig1
17,630
43,296
descale by draining down, filling the boiler and pipes with white vinegar. heat boiler up then leave for 24hrs. drain down and refill with water. test and repeat if neccessary
do this every 12 months or more frequently if youre often filling in a hard water area
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
Norman
Personally, I'd fill it up with citric acid and go for a drive. You'll need several packets and need to find a way to insert directly into the cylinder. I don't know enough with Trauma heaters to advise how.
Also, make sure the thermostat is correctly located. It should be near the bottom, as only water above the thermostat is heated.
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Hi I dont think it's the wrong board simply because I dont think others will fit --bleed system by turning HW tap on until spluttering stops -wc room as well-
ring truma :thumb:Link Removed
terry
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Open the furtherest tap away from the tank/Boiler first...
Then the next nearest and so on...
Do it on both hot and cold,,,, till the water runs smoothly.. :thumb:
43,331
49,461
terry
only thimg thats changed...a new board fitted.
if it isnt the wrong one its probably faulty/
normanandsue
normanandsue
1,871
21,571
van conversion
It has always given short measure of hot water ie not enough to manage a short shower
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
Am I right in understanding that the thermostat is in the circuit board housing?
Ours gets extremely hot and I wonder if the thermo is OK
Wyn
FULL TIMER
795
717
NORWICH
SELF BUILT IVECO 75E17
BEEN BUILDING THEM FOR 32 years
I think what you might be forgetting is that for every litre of hot water you use it is immediately replaced with a litre of cold, not a problem if only using small amounts at a time as the new cold quickly gets heated, when showering I'm guessing that you leave the water running continuously instead of the wet the body, turn off, soap up, rinse off technique. for a bit extra you can allways turn on the gas at the same time as the electric.
marksmith
33
19
Hampshire UK
Low profile coachbuilt
Since 2008. Owned since July 2013.
Hi normanandsue,
What happens after you get the 6 litres of water? Does the water stop, or is further water cold?
-Mark
