Hose Pipe Connectors (1 Viewer)
ShiftZZ
21,383
84,577
Dark Side of the Moon
SERIOUS QUESTION
Last week Mrs ShiftZZ and I took our new van to France, we did not carry water in the Autosleeper besides the 'toilet' flush. All drinking waster was bottled.
In the Rapido, there is only one central tank to hold all water, so we had to fill it up at an Aire (yes I used a watering can). The Water Output from the Aire appear to require a screw on attachment for a hose pipe.
Can any funster advise as to what connectors I should ask MrsShiftZZ to get? (Delegation is always better as if it goes wrong then its not my fault) So bear this in mind, Mrs ShiftZZ will get the blame if you mess up....
As always
ShiftZZ
DBSilverfox
583
97
Nottingham
coachbuilt
Since May 2010
I got mine from Homebase. you can get a connector there that takes two different widths of tap, one adaptor screws into the other for storage.
Hope that helps
David
Heyupluv
3,862
1,593
France,
touring many years..42+
SERIOUS QUESTION
As always
ShiftZZ
Dave,,,,,,ALL THREE !/2"....3/4"....1" ....plus rubber connection if you are going to tour in France 3/4" is the most used...I will send a ebay list ......they are not expensive for a man of your calibre:ROFLMAO::ROFLMAO:
Mel:thumb:
Heyupluv
3,862
1,593
France,
Mel:thumb:
Link Removed
Link Removed
Link Removed
Link Removed
Link Removed
Mel
Jim
Ringleader
Jul 19, 2007
36,421
130,916
Sutton on Sea, UK
Adria Panel Van.
Since 1988
We have a tupperware box with lots of different hose fittings, all the connectors 1/2 3/4 and 1, as well as the screw head clamp on ones when you just get the french tap that resembles an old bath tap with no thread, along with joiners and 3 way splitters so you can hook up with others hose. I find one of each is not enough as I'm always losing them
Heyupluv
3,862
1,593
France,
Link Removed
Link Removed
Link Removed
Link Removed
Link Removed
Mel
Dave "Tell"...No better..Advise is better Mrs Shifftz...you also require a hose pipe ...we have one cut into thee different lengths....but can connect together if needed and sometimes you do need a long length:Doh::ROFLMAO:...what we use to connect then together are these
Link Removed
and these
Link Removed
4,077
6,547
Wirral
Hobby Van Kenobi
started when I was 11 with my parents-forgot to stop!been real one since 1980!
I found some Borns required this fitting to connect to the water output and the hose.
Broken Link Removed
Heyupluv
3,862
1,593
France,
Dave "Tell" or advise is better Mrs Shifftz...you also require a hose pipe ...we have one cut into thee different lengths....but can connect together if needed and sometimes you do need a long length:Doh::ROFLMAO:...what we use to connect then together are these
Link Removed
and these
Link Removed
If you have this type of water inlet
Link Removed
It is worth buying one of these drain pipe off set bends
68x68/112'..PVC off set bend
Link Removed
when you take your lockable cap off push one end into the opening, (mine is the collar end that fits) it makes it a lot easy-er to fill with watering can or a larger container like mine 10 ltrs
This will save Mrs Shiftz spilling any water when filling plus Mrs Shiftz could carry the larger container like mine 10 ltrs to save going back so many times
Mine was about 4 euros from Lidl bright red brill, with spout if needed or without spout for a quick fill.....
similar to this one but it is better one from Lidl...
Link Removed
:thumb::winky::ROFLMAO::ROFLMAO:
Mel
WynandJean
6,670
3,303
West Midlands
Bailey Autograph 682
Since 2010
Could I also suggest one of these:
Link Removed
Saves standing and holding the end of the pipe in place, or having it keep falling out of the filler neck.
And we keep all our connectors, filler etc. in a small zipped, cool sandwich bag thingie from the pound shop
Wyn
Heyupluv
3,862
1,593
France,
Link Removed
Wyn
Dave.. what Wyn has suggested are good..... we have one (they are not cheap) but very good ....they save you when you at the opposite side of your van pressing the water tap button in to get water only to find your hose pipe has come out and you have been watering the grass ???:cry::winky:
Mel
Terry
11,932
9,084
Lincolnshire
Can't remember ;)
Link Removed
Link Removed
Link Removed
Mel
:Eeek: I pay about 90p for them-offset bend that is ::bigsmile:
terry
Heyupluv
3,862
1,593
France,
terry
Terry...the ebay item No (as with all the others ebay No... I have put on) are just an example, pictures only nothing more,... just to show Dave ......it is not up to me to suggest to Dave how much to pay or where to buy from That is up to Mrs Shiftzz:winky:..... if Dave intended to buy any of the items, it is up to Dave to source the items and cost for himself ??:thumb::ROFLMAO::ROFLMAO:...Maybe you could get one for Dave at 90p and post it onto him:thumb:
( I paid a lot less myself, maybe that's because I was in the building trade:Doh::ROFLMAO: 49years)
Mel
Jul 28, 2010
1,710
617
The world
Small car
SERIOUS QUESTION
As always
ShiftZZ
we carry about five connectors as their are many types out there at least two different screw types plus taps sizes can differ too there is no standardization when it comes to taps and water supplies :cry:
Feb 27, 2011
14,737
75,990
UK
Self Build
I have seen that box in action at the fulltimers meet. Most impressed :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
Terry
11,932
9,084
Lincolnshire
Can't remember ;)
Mel
:ROFLMAO: more than happy to do that :thumb: I may have a couple in the garage :ROFLMAO:
terry
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
We have witnessed Johnny Foreigner favour this sort of device on the aires and stellplatzes!
Broken Link Removed
Heyupluv
3,862
1,593
France,
terry
Good man Terry :thumb:....Terry I hope they are new ones in your garage!!......and not used ones from off a job... or you will have to answer to Mrs Shiftzz ******:Eeek::winky::hardhat:
