Is it a good idea to keep the van hooked up to the mains on the drive during this cold weather to avoid the battery going flat? I notice a couple of vans locally that are hooked up and wondered what others do.
Yep hooked up and got little tubular heater on all the time on a frost controller .also of course keeps batteries charged. .RoyIs it a good idea to keep the van hooked up to the mains on the drive during this cold weather to avoid the battery going flat? I notice a couple of vans locally that are hooked up and wondered what others do.
My van is gas only heating . Otherwise I would consider it. Roy@Khizzie @hilldweller @rangitira @cornish boy
May be a silly sort of a question but...
If you've got the van hooked up, why put a heater in rather than use the van's own heating system?
Not found that in 9 years sorry.Schaudt who build chargers for a lot of german vans say that you should not leave them on hookup for long time periods.
A cold van in cold weather wont suffer condensation. But a van heated warmer than the ouside temperature will get condensation so I dont heat ours when not used
Temp does not matter, just keep that battery topped up.
I will repeat myself , I have had no issues with condensation in my autocruise stargazer in the 9 years I have had it. Other foreign built vehicles may suffer from it in certain circumstances..i wouldn't know about that ... My batteries don't seem to have suffered from being on charge foe extended periods. . Others may have had issues but I haven't. RoySo...maybe there are two questions:
1. I assume that if you are on hook up, both the vehicle battery and the leisure battery are on charge? If my assumption is correct,is this a good or bad thing??
2. Is jezport correct in his statement re condensation? Seems logical to me,but I know little. If the motorhome is kept in storage thru December to January is it necessary to do any of this?
Maybe better to take it out for a run every 2/3 weeks?
Pod.
As we drink the water from our tank we always empty it when we get home so don't have to worry about it freezing, and we have an old set of external screens which we leave on the van when it's at home in colder weather to keep the cabs windows clear in case we want to use it.We keep ours on ehu while on the drive with the heating on low (electric) so we don't have to drain down the water. Also keeps the Frost off the window so I don't have to freeze scraping it off.
