Hi a newbie need help (1 Viewer)
nearlydone
5
3
Fiat ducato Auto Cruise
newbie
Hi We have just got a Fiat Ducato Auto Quest 270. 1990 diesel 2.5 The van drives well for an 45 mins then loses power. A Lot!!! We have had it serviced and all new filters and it is still not running properly any advise please.
Puddleduck
12,385
43,990
Scottish Borders
Without at present
On and off for many years.
:welc:
Sorry can't help with your problem but someone will offer suggestions soon.
Apr 19, 2014
40
10
That's the problem it's a Eurobox
Should have gone for an RV.
Sounds like you have a sensor failing. When it get to wards working temperature
Get in to a good diesel diagnostics. Not sure where your at there is a good one in Middlesbrough. But may be a bit far from you
Try a google in your area for a remapping / diagnostics.
Hope you get it sorted
Yours Ian
Carol
14,051
112,114
North Wales.
Hi nearlydone welcome to fun, hope it's sorted soon and not to expensive.
TheBig1
17,630
43,324
very much a failing sensor or a fault putting the engine into "limp mode" when it gets hot
it needs to be run up to temperature with a computer attached to read the codes to find the fault
oops just reread and its an old 1990 so pre computer. may well be a pump and or turbo fault or even as simple as a perished rubber diesel hose. needs expert investigation by a real mechanic, not a modern fitter
Nov 18, 2011
11,862
43,044
Planet Earth
A van
Over 25 year's
Is the fuel cap breather blocked try driving with out the fuel cap or put one of those tempory ones on.
Or drawing air in the fuel system is it 2.5TD
N
nearlydone
5
3
newbie
Have a good mechanic who will be looking at it but seeking advice we think it maybe fuel related?
N
nearlydone
5
3
newbie
thanks bill worth a try.
RS_rob
1,010
669
Turnford
over a Year Yay................
Hi & welcome I do not intend to diagnose your problem I just wish to give you a heads up if incase your mechanic find nothing wrong as what yo have to make a note of is the fact that old diesels were in fact inherently slow & required some coaxing.
Modern Diesels are infact the complete opposite requiring no downshifts but just an eye on the road & knowing when to apply the throttle to maintain maximum torque.
You will learn the best way to drive your van eventually :winky:
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
The Fiat 2.5td is a pretty willing engine and certainly doesn't need coaxing. Is yours the turbo or non-turbo?
Apr 13, 2012
5,545
18,775
Mobilvetta Euroyacht
1996, then break 'til 2011
My 1991 2.5d needs no coaxing, pulls up hill in 5th and has so much torque that 1st, 2nd and 3rd gears are hardly needed once you're on the move.(y)
Welcome !
(y)
PS Think Bill might be right - sounds like fuel problem
