Help (2 Viewers)
Clive
1,296
1,782
Canvey Island
High Gain Long Distance USB Directional Antenna model NET-WL-USB-UTP2470-12 MKII
I've just bought one of these from Faculty-x. I have tried everything to make this work on my windows 7 Samsung PC. My PC recognises it when plug in but shows as disabled. I tried everything I can think of but not get it working. It has been back to the supplier and he has proved it works.
Any ideas gratefully received
:cry:
wingman
1,217
3,333
Romford, Essex
Coachbuilt Lo-Profile
Sounds like 'Driver' problem?
If you haven't already, try this......
Go to Control Panel and select 'Device 'Manager'.
With Device Manager now open, locate the hardware device you want to enable.
Navigate through the categories of hardware devices by clicking the > icon. Specific hardware devices are listed under the major hardware categories.
After finding the hardware you're looking for, right click on the hardware's name or icon and click on Properties.
In this Properties window, click the Driver tab.
Now click the Enable button.
Click OK.
This device should now be enabled.
You should now be returned to the main Device Manager window and the black arrow should be gone.
Clive
Clive
1,296
1,782
Canvey Island
Click OK.
unfortunately, been there and done that, everything tells me it's enable except change adapter settings which shows it as disabled. Click enable, it says it's enable but still displays as disabled. :cry:
17,635
43,358
did you try to disable the built in wifi card first to avoid resource conflicts?
Clive
Clive
1,296
1,782
Canvey Island
yes disabled existing wireless, also virus guard and firewall. Tried various combinations of this. Has to be a conflict somewhere but where is now beyond me
jaytee74
72
37
durham uk
coachbuilt swift royale
since2007
i note everything you have done which is exactly what you should!!!!! the only thing i can think of is that an add-on may be creating a problem so i would get rid of all add ons delete all cookies and browsing history and double check that nothing is running in the background then start from scratch and try loading again.. good luck jt
17,635
43,358
just a random thought, had this work a few times with usb accessories. leave it plugged in and reboot the computer and trick windows into reallocating resources
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
I had the same problem with that booster on my Toshiba, can't really remember how I solved it but keeping it plugged in and rebooting could have been the cure.
Good Luck
Peter
Movinon
277
301
Lots
What firewall are you using? It could be a firewall problem. If you're using a third party firewall it may not recognise your aerial so try uninstalling it (a full uninstall). Then plug in the aerial. Then reinstall the firewall with the aerial already plugged in. This may persuade it to recognise the aerial. However, you may find you have to rely on the windows firewall when using the aerial if this does not work, and you may not be able to use a third party firewall (i.e. have it installed) with the external aerial. If so, talk to the firewall provider.
Clive
Clive
1,296
1,782
Canvey Island
Thanks everyone for all your help. Yes it was the Zone Alarm firewall, even though I had turned it off. Uninstalled it, reinstalled my RaLink software and it now works perfectly. I shall try it out at Chester.
I love this site :thumb:
