Help with water problem (1 Viewer)
Jul 29, 2011
2,697
22,204
Urmston, Manchester
Former owner.
June 2012
Hymer 694 - when i run a tap i am getting water coming out from the outside connection quite a strong squirt until i turn the tap off then obviously it stops as the pump has stopped.
Anybody else had this problem and does it need the fitting to be changed.
TheBig1
17,630
43,277
by outside connection, do you mean external shower connector or the filler port?
If its the outside shower, the seal that makes it watertight when removing the hose may be perished or jammed. may be able to strip it down and repair with new o rings etc. if its the water filler, have you had the pump out and put it back in back to front?
PaulyP
Jul 29, 2011
2,697
22,204
Urmston, Manchester
Former owner.
June 2012
Cheers Big1
should have been more specific,:Doh: it's the outside shower point.
I will prob take it off tomorrow and have a good look at it, didn't get chance today.
