Help with Schaudt Elektroblock email please (1 Viewer)
Sep 3, 2009
1,532
6,282
NW Surrey
LHD Hymer exsis-i
Hi all
2012 Hymer exsis-i 562
Can anyone help decipher an email I had from Udo Lang at Schaudt? He recomended I connect my 600wat inverter to the starter battery since I will only be using it whilst driving and I didn't want to risk upsetting the EBL 99 K.
I want to connect the relay via a rel;ay to avoid inadvertently flattening the battery. I emailed UDO about where to pickup the D+ supply for the relay and he sent the following reply.
"please see the wiring diagram in the user manual of the EBL 99.'
You will find the D+ as a positive signal 12V on the block 1 (4 pole connector) at the EBL on pin 2.
There is a D+ point to switch some users."
I know where the supply is but I don't understand his last serntance, when I queried it he just repeated it. The previous owner has inserted a blue 3m Scotchlok into the D+ output already. Does he mean me to do the same?
I must admit I think the electrics aren't one of Hymers better points.
Malcolm
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
I think what he means is that the D+ connector is there on the EBL so that it can be used as a control signal to turn on or off power to items that should only work when the engine is running. Block 1 is the refrigerator relay connector on the EBL99, so that makes sense, as the fridge should only switch to 12V when the engine is running.
For 'some users' read 'certain electrical items'.
In other words, I think he's confirming that it will do what you want.
E
Sep 3, 2009
1,532
6,282
NW Surrey
LHD Hymer exsis-i
I think you're right, but it seems strange to me that with all the technology and attachments on the Schaudt system you still have to resort to a 3m Scotchlok connection.
Malcolm
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
TheCaller has interpreted Udo's comments correctly in my view. Udo often refers to 12V electrical circuits / appliances as 'users' or 'consumers'.
It is correct that Pin 2 on Block 1 of an EBL99 is the D+ feed so you can pick up a feed anywhere along that cable. If you are connecting your inverter to the starter battery (not something I would do) then is the EBL the most convenient place from which to pick up a D+ feed, or would it be easier to trace it from the alternator in the engine bay?
Why not connect the inverter to the habitation batteries (assuming you have more than one to provide sufficient capacity). You will not upset the EBL unless you allow the inverter to run down the hab. batteries significantly in which case the EBL will shut down the 12V system once it detects an 'under load' voltage of 10.5V. You can still fit a relay to operate the inverter although I would rather go for a manually switched one since you might not want to run it only when the engine is turning over.
For an example of wiring your inverter, may I refer you to the article that I posted in the resources section a few years ago? Mine is only a 150W inverter but the principle is the same. I have an EBL99 in my Hymer and the system works perfectly well. http://www.motorhomefun.co.uk/forum/resources/install-a-small-inverter.17/
p.s. I have found the Hymer wiring system to be very straightforward once I worked it out (and I'm not an electrician).
JeanLuc
3,304
2,199
Warwickshire
Malcolm
You don't, but you will need to extract pin 2 and fit a new one into which you have crimped an extra cable to activate the inverter. The pins require a special tool to get them out of the MNL plug otherwise you will destroy it as they snap into place with metal barbs.
Lenny HB
53,430
149,981
On the coast in West Sussex
Hymer B678 DL
I have a 1000 watt inverter connected to my leisure batteries does not cause any problem with my EBL29 (newer version of EBL99), I fitted the inverter under the passenger seat so the cables were kept short to the battery well to the side of it. I fitted a 100 amp fuse inline directly to the battery terminals and next to the inverter I have an isolation switch.
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
Replace the existing ScotchLok connectors with these:
The best method of adding extra lines off the feed is with these WAGO connectors
You will probably find that this type of connector is already in use in your van.
They are available via eBay - search for Wago connectors. As Techno said in his original post, search carefully because prices vary considerably.
E
Sep 3, 2009
1,532
6,282
NW Surrey
LHD Hymer exsis-i
Thanks for your replies. My options are limited due to the fact that we've only just got this MH and we go away in a couple of weeks. Also it only has a single 95AH Banner AGM battery at present
Fitting the inverter to the starter battery was Udo's recomendation, and since Atlantic Caravan Repairs (,who appear to talk sense.) wont even discuss inverters with the EBL 99 K other than repair costs I decided to go along with that. It is only for my electric bike battery primarily and my Dell laptop, so will only be used whilst driving.
On my 2012b Ford based exsis 562 I don't think I could even find the alternator, let alone trace the wires!:)
Replace the existing ScotchLok connectors with these:.............
If you don't think I would suffer a current drop using them that's a good idea. I've got plenty of those in different sizes and use them a lot. Again not knowing much detail about electricity I was concerned they might cause a current drop. My system already has a Elektroblock DP 02 A D+ booster fitted for some reason. Should I be concerned about that?
Malcolm
Lenny HB
53,430
149,981
Hymer B678 DL
Oh dear better budget for new batteries then. Both my Banner AGM batteries failed in 18 months in my 2014 Exsis.
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
I'm keeping my fingers firmly crossed, but mine seems to be still ok after 3 years & some serious abuse by a dodgy solar controller that was allowing the battery voltage to rise too high on sunny days (16v+ :().
Suspect I'm on borrowed time though - irrespective of make.
