Help with pwm solar charge controller (2 Viewers)
flatpackchicken
1,277
1,757
BICESTER OXFORDSHIRE
A Class Frankia I8000
Since nov 2009
Help wanted please on PWM solar charge controller,,,,
Power was discontinued for a few weeks and now showing an H instead of a continuous 1234 as before but seems to be still charging from solar panel, and the Power light is on and showing green also charge light is on and showing green as well,, any ideas please, Regards Garry Flatpackchicken
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Temperature too high?
Digital tube displays
“H” with red slowly
flashing
Too high
temperature of
controller
When heat sink of the
controller exceeds
85 ℃, the controller will
automatically cut input
and output circuit. When
the temperature below
75℃, the controller will
resume to work
Notes: No LED indicator.
Measure battery voltage with multimeter.
Min.6V can start up the controller.
Notes: No charging status LED indicator with normal
connection. Measure the input voltage of solar module,
the input voltage must be higher than battery voltage!
flatpackchicken
flatpackchicken
1,277
1,757
Since nov 2009
Thanks Jay much appreciated mate, although the H is on all the time and don't flash????? Regards Garry Flatpackchicken
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
Have you tried disconecting it & reconecting (in the correct sequence) again?
