Help Truma dumping water (4 Viewers)
May 23, 2013
1,782
2,816
Not on the Coast East Sussex
Hymer B504
Just filled up with water in preparation for our trip to Germany leaving Boxing day and with the water pump on the Truma boiler is dumping all the water.
The push/pull valve is in the closed position and the temperature should is above 8 degrees currently, we have a C3402 and I have put the heating on to see if that fixes the problem but any helpful suggestions would be greatly appreciated.
GJH
29,450
38,827
None, now sold
2006 to 2022
Do you also have a yellow manual lever like the one in the diagram? If it is in the horizontal position (as it should be) try opening it and then closing it the other way. Sometimes they don't close properly.
Apr 23, 2010
945
1,777
Isle Of Man
4 years
Hi you also have a frost protected valve some have a blue knob on the top of a black casing whch has a small button on or near its base that must be pushed in and remain in,it can be in colder area of your MOHO i.e. under the kitchen sink check that this is in.
53,448
150,071
Common problem is the air vent valve in the "T" connector at the top of the heater where the hot water outlet is.
Leisure Shop Direct stock them.
Obviously too late to get one for Boxing day, may get away with cleaning it, take it apart and soak in a 30%-50% solution of hot water and white vinegar (white wine vinegar works best).
If it is the valve & cleaning doesn't work should be easy to pick one up in Germany, I think the same valve fits all the Truma combi's.
orridge
May 23, 2013
1,782
2,816
Hymer B504
thanks all, just back from Sons nativity.
@Graham it's the push/pull type
@Lenny thanks will have a look at that
The push/pull valve seems to be working ok as when it's open it dumps what but when it's closed and the water pump is on it also dumps the water.
orridge
May 23, 2013
1,782
2,816
Hymer B504
I have a red valve by the boiler but I am at a loss to find a blue valve anywhere. Have checked all the cupboards but nothing.
It's a Euramobil A Class so even had a look under the floor.
53,448
150,071
That is because you don't have one. The blue is the latest mechanical dump valve on the C4 & C6 Combi's, earlier versions C6000, C 6002 etc., had a red electrically operated dump valve.
orridge
May 23, 2013
1,782
2,816
Hymer B504
I am not sure if it's related but we are getting minimum water out of the taps when the boiler is dumping water with the pump running. If the valve is in the up (closed) position how can the water get out when the pump if running but not when it is not running ?
53,448
150,071
Check and make sure which pipe the water is flowing out of under the van, there should be a two pipes one for the dump valve and one for the vent valve. I'm betting on it being the vent valve where the hot water draw off is.
53,448
150,071
Good news, it is only there to vent air out of the boiler while filling, should be able to clamp it off as a tempory fix.
Reactions: f6c
f6c
Nov 7, 2010
10,960
4,793
gloucestershire
Carthago Malibu 640
23 Years
No clip it at the end of the plastic pipe under the van. ie outside:xgrin: don't panic i had this problem for 4 weeks in Spain this year. The new part cost about ÂŁ5:00 PM if you want.
orridge
May 23, 2013
1,782
2,816
Hymer B504
it would appear to be a faulty vent valve so thank you Lenny, clamping has reduced the flow enough to use the taps whilst we source a replacement part next week in Germany.
Merry Christmas all and a special thanks to Richard @f6c for taking time out of his busy christmas to speak to me on the telephone to troubleshoot most appreciated.
Guy
Reactions: GJH
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Whilst you made a correct and sensible diagnosis I'm afraid I disagree with your description of this valve's purpose Lenny, it is not there to vent air out of the boiler, it is there to allow air into the boiler when draining down.
D.
orridge
May 23, 2013
1,782
2,816
Hymer B504
Well yes it was a faulty vent valve and easily found in Germany for about 4 euro so thanks for all the suggestions.
Shame the exhaust just came loose on the motorway and currently awaiting ADAC to come and give us a tow. Hope that safeguard cover is working fine.
53,448
150,071
Turning into an interesting trip, they come in 3's you know, we are waiting for the 3rd.:xgrin:
Good luck with getting it sorted.
Bertie Bassett
2,743
8,702
since 1988
Good luck but ADAC on the ball both times we have called for assistance over the last 27 years.(y)
53,448
150,071
3rd one is the gas is playing up and only filling up the first bottle.
Oh no!
Could be sticking non return valve in the bottle that is not filling, can't think of any other reason for it.
How cold was it when you filled up? I've had problems when below zero it's taken over 10 min to fill once, suspect garage tanks were low.
Probably worth trying another garage pressure might have been on the low side.
