Help!! Status 315....... (1 Viewer)
Tavsday
3
Leicestershire
VW Coachbuild
Since 2001
Just upgraded from a traditional vw camper to a motorhome to make things easier with our 3 year old!
We just went away on our first weekend with the idea of cbeebies being on tap, however our status 315 doesn't really seem to be cutting the mustard. Will a booster do us any good (if so what do you recommend?) or do we need to completely change the arial? We don't really want to fiddle with the roof if poss as we don't want any leaks?!?
Any help would be much appreciated
Many thanks ::bigsmile:
TheBig1
17,630
43,310
There is a digital amplifier available from status that apparently works well
Dec 23, 2007
4,077
6,547
Wirral
Hobby Van Kenobi
started when I was 11 with my parents-forgot to stop!been real one since 1980!
Have you got the right polarity? Vertical or horizontal. Horizontal,ie the plane of the aerial is flat and usually for main transmitters, Vertical,plane is up and down,is for repeater masts generally the ones we find on sites. Digital was originally fed through repeaters. If you can look around at any buildings and see where they are pointing. Or copy a fellow camper.
43,331
49,465
the omni directional 315 will never be any good unless you are close to a transmitter.
cut your losses and bin it for a decent directional one through the roof.
fitted properly they do not leak.
i have, in the past, used an normal house aerial on a pole attached to the rear ladder...never failed to give good results.
43,331
49,465
Yeah right :roflmto:
I've seen aerials pointing in every possible direction on campsites and show grounds. :Doh:
i suppose one or two must have it right but its far better to note local house aerial direction as you approach the campsite etc.
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
i too have used a household aerial on a pole fixed to my rear ladder it may not look as nice but it works and costs about a 10th of the price.
like now i have a sky mesh mini dish clamped on a pole on the ladder total cost was around ÂŁ10 for the cable the dish was a scrap one off an installer.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
You need to use the MotorhoneFUN technique to improve your 315.
First remove from roof.
Place on flat smooth soft grass.
With the aid of an assistant drive over it with the motorhome.
Repeat until you can no longer see the 315.
Go buy a Status 550.
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
most of them just use their satellite systems so never bother with the normal aerial.
T
Tavsday
3
Leicestershire
VW Coachbuild
Since 2001
Thanks all!!
Thanks everyone for the sound advice! Think it's time to get the big mallet out!!
:thumb:
43,331
49,465
:thumb:
Incidently....if you do decide to change the 315 you dont have to remove the base plate.
you can buy a blanking plug which fits in/on the base plate after removing the 'saucer' part and the coax cable.
Blanking cap
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
:thumb:
I wonder if you'll be luckier than I was. The directional aerial had to be in a slightly different place due to the pole hanging inside. Very nerve-racking to stick one big hole-saw through the roof.
T
Tavsday
3
Leicestershire
VW Coachbuild
Since 2001
315
Yeah same as us that is why we're a bit reluctant to change it, I see most people have them fitted in their wardrobe but we're the other side, with just a small cupboard underneath....
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
They do make a short cupboard version of the 530
The 530/5 with a 365mm mast (Top Cupboard Fitting)
The 530/10 with a 920mm mast (Wardrobe Fitting)
Dont throw throw the old unit away they make great frisbies:thumb:
Fosdike
ripon
van
Absolute rubbish, I have used a Status 315 for years and there have been to very few places that I have had to resort to getting out the satellite dish because i cannot get a terrestrial signal. Now that the majority of Freeview transmitters have significantly upped their power output I think us flying saucer owners are going to have the last laugh as we watch you lot fiddling around trying to locate a good signal when all we have to do is plug in and switch on. Regarding one of the previous posts, It is not unusual to find people who didn't realise it had to be switched on.
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
Absolute rubbish, I have used a Status 315 for years and there have been to very few places that I have had to resort to getting out the satellite dish because i cannot get a terrestrial signal. Now that the majority of Freeview transmitters have significantly upped their power output I think us flying saucer owners are going to have the last laugh as we watch you lot fiddling around trying to locate a good signal when all we have to do is plug in and switch on. Regarding one of the previous posts, [HI]It is not unusual to find people who didn't realise it had to be switched on[/HI].
Last year I pulled up at Durdle Door campsite. I managed to get a fairly poor picture on my Staus 315 on a day when many wanted to watch the Grand Prix. Their super duper wind up dish's got nothing and they crowded into mine to watch the GP.
Picture improved no end when I remembered to switch on the Booster.........:ROFLMAO:
