Help! Silicone sealant (1 Viewer)
jennymaywright
95
5
Shropshire
Low Profile
Does anyone have any good tips for removing old silicone sealant from around a sink and the shower room wall? Jenny
Terry
11,932
9,082
Lincolnshire
Can't remember ;)
Hi use a small paper scraper/ filling type knife-- if it is on paper covered boards be very careful not to go through the paper- :Eeek: :thumb: It may be worth while masking up and cutting through the paper on the board then re masking and sealing.
terry
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
I've just been doing that, on the roof removing an aerial. If you can get an end and lift and slice under it keeping it as a string it helps.
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
Once you get the worst of it off using a knife, moisten one of those green cloth scourers with turps and gently rub the remains of the sealent. It should go soft and then just rub off. You might have to keep moving your finger on the cloth because it might clog up.
7
7735
silicone sealant remover, comes in a tube like the sealant, available from B&Q or most DIY's
spongy
