Help required with setting GPS (1 Viewer)
Portland
923
1,424
Conwy
C class
20 years
When using my Garmin Sat Nav for co ordinates I'm confused by some details. When you have a setting of say N50.27.36 how should I enter the 36 as there are 3 spaces to do it. Should it be 036 or 36 or what:whistle::whistle:
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
Use Garmin settings to set up the entries as say .... 50.56789 etc. Handy, because if you ask Google maps for a "where is this" it gives it to you in that format. Then you can just enter it and navigate to it. :)
Oct 18, 2014
1,858
1,157
Salisbury
Hymer B598 PL
Since 2013
Agreed, much easier way to set out the figures
Lot lover
1,291
1,617
Lot, France
Le Voyageur Integral
New boy
But not the British way .:D
It is easy enough go on-line to find the way to convert to proper deg/min/sec
Jul 29, 2013
9,071
18,539
Salisbury
Hymer B678DL A class
since 2011
If you go to settings there are different foremats for input of coordinates.
If unsure I put a nought in front and then let it show you on the map.
scotjimland
2,335
10,105
A Woosh bang
GPS Degrees in decimal format, ( as shown by @Speve ) are much easier to use.. and less chance of being entered incorrectly.. and as already mentioned.. can be lifted straight off a Google map in that format
