funflair
oops
My 1000 watt inverter looks identical so probably came out the same factory.BRAND NEW
QUALITY PROFESSIONAL
2500W DC12V-AC240V PURE SINE WAVE POWER INVERTER
Free Next Working Day Delivery to Mainland of UK
If you order and pay before 2:00pm we dispatch your item in same day
FEATURES
Advantages of Pure Sine Wave inverters
- Fully automatical protections
- Soft start, high stability and quiet performance
- Cooling fans are controlled by overheat protection system so only running when too hot
- AC output and DC input voltages digital display
- LED Indicator light
- CE approved
- Suitable for household appliances, lighting, electrical tools and office equipments etc.
SPECIFICATION
- a) Output voltage wave form is pure sine wave with very low harmonic distortion and clean power like utility-supplied electricity.
- b) Inductive loads like microwave ovens and motors run faster, quieter and cooler.
- c) Reduces audible and electrical noise in fans, fluorescent lights, audio amplifiers, TV, Game consoles, Fax, and answering machines.
- d) Prevents crashes in computers, weird print out, and glitches and noise in monitors.
- e) Reliably powers the appliances that will normally not work with modified sine wave inverters
Continuous Power 2500W
Peak Power 5000W
Output Waveform Pure Sine Wave
Maximum Efficiency 85%
Input Voltage DC12V
No-load Current <0.7A
Output Voltage AC220-240V
Output Frequency 50Hz±2Hz
Fuse 350A
Soft Start Technology Yes
Cooling System Fans
Overload Protection Yes
Over Heating Protection Yes
High Voltage Protection Yes
Low Voltage Protection Yes
Output Short Circuit Protection Yes
Weight 4.7KG
Dimension 460x160x130(mm
BRAND NEW
Make it sweat as well I guess.Just looking at that picture makes me sweat, god knows what it would do to a battery.
There's your problem. Very bad practice installation - tenner says he's taken the neg to the closest handy bit of bodyworkI can't see where the auto electrician has taken the negative from, I will have to ask as it doesn't appear to come from battery directly which is what I expected using similar lengths of the same 25mm cable?
Voltage of battery 12.9v, back of inverter 12.9 V, under load of 500w 10.5v!!!!
Yep, definitelyI think I need the auto electrician to explain his mysterious wiring and to run additional cables,
We double up cabling all the time - especially on large cables, its's common and accepted practice. Both cables should really be the same CSA, so go for 2 paralleled 16mm2 back to back with separate crimps ... none of that sharing the same crimp malarkey !If I double up the 25mm would that be ok in everyone's view? As access is an issue he may need to add another 16mm cable making it 25 + 16 ( 41mm)???
So with two cables doubled up do you just fuse each one individually and then remember that the other side of the fuse will be live?There's your problem. Very bad practice installation - tenner says he's taken the neg to the closest handy bit of bodywork
25mm2 is ok for 125A (1500W) at 900mm cable run.
To do - run a 25mm2 cable from neg side of the battery to neg side of inverter.
I'd also recommend fusing at the battery (pos) end.
Yep, definitely
