Help re topping up something in the engine (2 Viewers)
movan
21,492
120,753
Moving around
Burstner
since07
Sorry can't get to my motorhome instruction manual. Whilst checking for mouse damage in the engine, spotted this seems to have dropped down quite a bit and might need topping up.... Can you tell me please//
a. What is it and what do I ask for from the shops?
b. The previous owner has obviously marked the lids with yellow dots .. I can't quite work out how to open the tops and why are there two?
Thank you. I accept it probably a daft question. :(
Badknee
7,407
412,734
notloB
Vantage Neo
Living the dream.
That is a header tank for your radiator. If it was mine I would take the opportunity to top it up with antifreeze. It will have some in but you do not know the strength. So neat a/freeze for me.:)
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Gerflunkel fluid. You are at a critical level in gerflunkel fluid. Evacuate the area immediately and call the police and fire brigade.
Go to Halfords and get some Megga Gerflunk quickly before the whole engine implodes.
movan
movan
21,492
120,753
Moving around
Burstner
since07
Thank you, but do I have to ask for a special anti freeze for a motorhome and do I dilute it with water? Thank you. Is it possible to put too much anti freeze in and would it do damage. (I don't mean by that overfill it, I mean strengthwise) . :)
43,329
49,444
Not daft at all Joy, if you dont know what it is, you dont know.
Its your radiator water expansion vessel and it will have a mark for COLD and another for HOT.
As long as the level is at cold when the engines cold thats fine...NEVER try to remove the cap with a hot engine, it will scold you.
The cap twists off anti clockwise but will be tight.
movan
movan
21,492
120,753
Moving around
Burstner
since07
Cheeky... I started writing Gerflunkel fluid on my notepad when I began reading your post!!!!!!:doh:
movan
movan
21,492
120,753
Moving around
Burstner
since07
:Ta2:
43,329
49,444
Too much antifreeze may cause overheating.
if the radiator never seems to need topping up i would use water.
if it needs regular filling use antifreeze and water...50/50 in winter...30water/50 anifreeze in summer.
If you should overfill it dont worry, the excess will be forced out the cap when the engine gets to temperature.
Badknee
7,407
412,734
notloB
Vantage Neo
Living the dream.
No just ask for a litre of antifreeze and put it in neat. If it doesn't get it up to the mark put some water in the a/freeze bottle, swish it around and put that in. :)
CWH
5,146
247,438
UK
WildAx PVC
From November 2013
"Help re topping up something in the engine"
Oh joy, this is priceless! Had me laughing with ... Joy! It's exactly the sort of thing I think whenever I look at anything mechanical.
I hate to be the useless little woman but isn't it great to have all these lovely experts on FUN (men and women) willing to help us out?
TheBig1
17,630
43,277
some vehicles use specialist radiator coolant. make sure you dont add water to one of those or you ruin it
use this for newer Fiats
Broken Link Removed
movan
movan
21,492
120,753
Moving around
Burstner
since07
Oh no.. now it gets complicated :( How will I know if my vehicle uses a specialist radiator coolanat or not. :(
Aug 18, 2014
23,782
133,652
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
You can see marks on side of tank stating "max" & "min" It s above min & just need bringing up to max whilst cold.
DBK
18,023
48,095
Plympton, Devon
PVC, Murvi Morocco
The answer to the original question, based on your pictures is no, it doesn't need topping up. There is no requirement to have it filled to maximum.
The servicing schedule will say how often the coolant is supposed to be changed but like brake fluid lots of folk ignore this advice.
What I would suggest is unless you have reason to believe the coolant is weak is only to top it up with the recommended mix of antifreeze and water.
TheBig1
17,630
43,277
check the handbook and the colour of the fluid already in there
added this to my post just before you replied, sorry
Broken Link Removed
movan
movan
21,492
120,753
Moving around
Burstner
since07
Broken Link Removed
Mine is yellow.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Looking at Joy's expansion vessel it is not paraflu
wingman
1,217
3,333
Romford, Essex
Coachbuilt Lo-Profile
Since 2012
Joy. Here's another tip..... DONT drop any residues of anti-freeze on the paintwork. It will take the paint off! Avoid also spilling any on painted engine surfaces.
If you are buying any, dilute it and decant it into a (clean) plastic milk or other bottle. It's easier to pour it into the header tank than trying with a full flaggon of neat ant-freeze.
James
movan
movan
21,492
120,753
Moving around
Burstner
since07
Oh no, now I've got to ask ..... what's a paraflu? :Eeek:
