Help please.. wifi (1 Viewer)
movan
21,492
120,753
Moving around
Burstner
since07
I know it is simple to you all ... but I am computer illiterate. Can you help please. :(
Found my old Asus tablet. Charged it. It ok.
Switched it on and also switched on my 3 wifi ... The tablet couldn't connect to internet .. it found the wifi but said it not authorised as it locked .(or something like that) .. how do I authorise the wifi to connect to the Asus please I have tried all the buttons .. settings .. wifi .. (and it shows my wifi but locked. )
Thank you.
Minxy
32,659
66,565
E Yorks
Carthago Compactline
If you click on the link to your wifi does it ask you for the secure key?
movan
movan
21,492
120,753
Moving around
Burstner
since07
No .. that is my problem .. tried every which way but loose. Can't get it to ask me for the secure link so I can type it in. There must be another way to get to that point.
movan
movan
21,492
120,753
Moving around
Burstner
since07
I suspect it something simple Mel .. if you were here you would see one of the headings on one of the pages and say 'ah that's it.' But I am rubbish with technology. :(
tonka
10,833
21,532
Cannock, Staffs
A class Burstner 800
Since 2000
Is there a "forget this network" button to click..
Sometimes you can delete the network. Turn wifi off and on again and then it asks for password..
Had to do this on our phones at home last week, no idea why it threw a wobbly.
movan
movan
21,492
120,753
Moving around
Burstner
since07
Will go and look.. it doesn't ring any bells though. I will try and put pictures of each screen.
movan
movan
21,492
120,753
Moving around
Burstner
since07
Minxy
32,659
66,565
E Yorks
What happens if you press 'connect' Joy?
movan
movan
21,492
120,753
Moving around
Burstner
since07
I click connect and authentication problem comes up
Minxy
32,659
66,565
E Yorks
A long shot but ... try turning off your 'location' and then turning it back on, it can sometimes confuse tablets! Don't ask me why but it does!
movan
movan
21,492
120,753
Moving around
Burstner
since07
Tried just touching screen to get any other messages .. nothing.. Tried just going straight from the home page into motorhomefun after doing all that and it just says not connected to internet .. I had hoped another message would come up there that says connect your internet etx with password and a place to do it.. or please authenticate internet 'here'.
Minxy
32,659
66,565
E Yorks
There's not an 'airplane' mode or something that could stop it connecting is there? You need to go through all of the settings, not just the obvious ones.
movan
movan
21,492
120,753
Moving around
Burstner
since07
Thanks both of you. :( No luck. Have to leave now .. will try when I get back to see if can find way round it. Ty.
movan
movan
21,492
120,753
Moving around
Burstner
since07
Gone through them to dou le check Mel. Everything seems set ok.
Talk later. X
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
On the Settings/WiFi screen touch the WiFi symbol and it should list all WiFis.
Forget/delete the one you want to connect to.
Turn WiFi OFF then ON and it should do another scan and then you can touch the WiFi you want and re-enter the key.
Dec 4, 2012
1,070
1,296
leicester
swift kontiki and vw cam
15yrs
Just wondering if it is like a phone that has been purchased through a particular provider and is locked into them. Did you get it as part of phone deal.
Lorryman100
640
1,015
UK/Scotland
Rapido A class
If there is nothing on the tablet worth saving do a factory reset which will return the tablet to the state you received it in. Then redo a wifi search, find your router and enter the routers password. The security protocol in your pic is WPA wich is a complex security algorythm compared to the older WEP based protocols, so at least the tablets security is current. By doing the factory reset it should clear the authentication protocol error as it looks like an app/program conflict is at fault. I use ASUS motherboards in my pc's and it usually takes me a couple of weeks to get everything running as it should, conflict free. JMTW (y)
