Help needed to remove panel (1 Viewer)
LPB
Aug 19, 2015
120
63
Crawley
Hymer B584
I'm a newbie
I need totals this panel out to get to the wiring behind
I have undone the 4 screws but I think I need to somehow undo the 2 large fixings in the top corners and maybe take the surround of the plug socket
Question is how do I do that?
Lloyd
43,331
49,463
I dont think the socket should need touching as the socket is fixed to the panel and will come out with it.
If you want to remove it a thin blade between bezel and wood should pop it off.
The panel may simply be stuck to its supports with age
Cant see why it should have a screw in each corner and secondary upper fixing points as well.
