Help. Lock jammed (2 Viewers)
malheg
175
72
Coppull (Chorley)
Campervan (Alphard)
12 yrs
Just a long shot to see if anyone can help.
The lock on my Hab. door is jammed, when I insert the key, it will not turn either way.
I can operate the door from the inside, no problem.
The back of the door looks to be a sealed unit with only direct access to the holding bolts at the top and bottom of the door.
I am off to Spain on Tuesday so in a panic.
Only solution at the moment is to lock the door from the inside and exit via the cab.
Fingers crossed.
Malc:Angry:
Fireman Sam
1,421
2,513
Bushey
Class C
Only since 2012, but I towed for many years
Or graphite powder, from a good hardware shop.
Trikeman
1,649
3,095
Wilds of Ceredigion.
AT 634 Apache.
Since 2011.
Agree with PaulyP,
a bit of WD40/GT85 and she'll be as good as new,,,,,, unless it's something mechanical gone fubar.
Usually just road grime and water sticking things up.
Trikeman.:winky:
Heyupluv
3,862
1,593
France,
touring many years..42+
Fingers crossed.
Malc:Angry:
Malc...this is just a thought...if the lock has just stopped without any prior signs resistance ...are you an area where children may squeeze superglue in the lock for devilment:Doh: other than that yes wd40...or the lock may be broken inside the barrel
Aug 18, 2011
12,140
18,005
derbys
AUTOSLEEPER SYMBOL
BIG HAMMER. BUSBY:roflmto:
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
Jesus, those French kids must get into some sticky situations ! :ROFLMAO::ROFLMAO:
Vlad
Heyupluv
3,862
1,593
France,
Vlad
It was just a thought Vlad....as the 5th of November Guy Faulks/Bonfire night.. had been moved forward/backwards.. to around the 2nd.. so the fires could be lit at the week end...
So has the Mischief Night been moved on again...as it was originally May Day....then it was moved to 4 November, the night before Guy Fawkes Night. .....I was just checking...... has it been moved again to today when Malc found his lock jammed solid:Doh:
4,170
5,156
Market Rasen
Since 2003
Do not use WD40 on locks as it sets and the lock will probably jam up even more.
Use a Silicon or graphite based product.
Mike
JockandRita
11,462
150,173
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
GT85 and a little red straw. :thumb:
However, the lock jamming could be caused by a mechanical linkage failing or becoming jammed itself.
Regards,
Jock.
Jun 2, 2010
4,924
11,290
Flintshire
Low profile
since 2010
Mike
Fair comment, silicon or graphite for lubrication but if the lock is already sticky or seized WD40 is what you need to free it off, nothing better:thumb:
estcres
1,300
767
Sunny Bournemouth
since 2005
Not teaching you to suck eggs but are you using the correct key?
Because i have quite a few keys on my keyring I have inserted the wrong one on a couple of occasions.
Just a thought.
23,836
72,507
WD 40... I love the stuff..
Over the years I reckon it has earned me an absolute fortune after folk have used it and completely screwed things up..
WD should NOT be used on anything electrical ( after a few weeks it starts to ABSORB water not repel it ).
WD is excellent for cleaning plastic things, quite good to spray on cuts and indeed cleaning other stuff PROVIDING ONCE THE CLEANING IS DONE THE WD IS WIPED OFF COMPLETELY.
As mentioned, graphite powder on locks..
Any sort of liquid will be a stored up problem.. **
I would remove the lock from the door
Lay lock on table and squirt graphite in to the key hole.
Use the key to spread it about
**Any sort of liquid used on an outside lock will cause a problem further down the road.
It will collect all the road dust and clog the darned thing up even worse as time goes by
If you DO have to resort to some sort of liquid, do try and get it completely dried out out when your done :thumb:
malheg
malheg
175
72
Coppull (Chorley)
Campervan (Alphard)
12 yrs
Lock
Thanks for the reply.
I do not think it is vandalism as we live miles from anywhere.
Tried WD40 & graphite, no luck.
Malc:Sad:
malheg
malheg
175
72
Coppull (Chorley)
Campervan (Alphard)
12 yrs
Lock
Just a thought.
Thanks, but only one key on my key ring.
Malc
malheg
malheg
175
72
Coppull (Chorley)
Campervan (Alphard)
12 yrs
Lock
That's my problem is getting access to the lock. The door seems a sealed unit.
But there must be a way.
Malc
23,836
72,507
Sounds more mechanical I am afraid
First thing to try would be putting the key in and tapping it lightly and repeatedly whilst applying a small ( SMALL ! ) amount of turn pressure.. Might work..
spotsy
28
Durham
since 2004
Hab. Door lock
Hi, I had a similar problem a while back with the lock on my door.Unfortunately for me the lock had broken inside and had to change the complete handle and barrel.This might not be your case though, the only way to find out is to remove the handle and examine the lock barrel and pray lubrication is all that is needed.I had a chat with the guy on following link.Hope this helps.http://caravan-parts.store.buegle.c...n-door-lock-motorhome-doorlock-/?k=:::3144436
Trikeman
1,649
3,095
AT 634 Apache.
Since 2011.
Hi, has it got (or had) central locking?
Seen it on AT where the central locking in the door went fubar and stopped the mechanism turning from the outside, but left the inside handle working.
If it has central locking may be an idea to try the front door locks, on off, on off may help.
Disassembly was the only way out in the end - new actuator/wire and job done.
Hope it helps,
Trikeman.:winky:
