Help -- leaks again (1 Viewer)
movan
21,492
120,753
Moving around
Burstner
since07
:Sad:Help please! Went to the motorhome today to check the engine started and realised that my waterproof, hanging up, was saturated. The water has come from the ceiling which was soaking ... it must have been a downpour as the coat was soaked as was the floor.
The wet ceiling spread from the wall right up to the roof window ... is it possible that it could just be the sealant round the window that has gone? The main wet part is over to the side of the roof, but I guess that water finds it lowest level so hopefully it is just running down to there from a small leak. I had no way of looking on the roof and will have to sort somewhere out to get up there and look but if prepared might stop panicking.
If not this what else could it be please, and will it be expensive?:Sad:
rolandrat
436
258
Lancashire
Hi Top
Help leaks again
It's possible that some snow could have blown under your Heki and caused the water ingress or you could have a dodgy window seal.
43,329
49,444
more than likely it's the roof light seal has failed.
needs sorting fast if its coming in that much.
as a temporary fix take some gaffa tape up there and once thoroughly dried off it will seal until you can make a proper repair.
Terry
11,932
9,082
Lincolnshire
Can't remember ;)
Hi Joy by roof window I take it you mean a roof light / vent ?
Until you get up there and check it could be as simple as roof light seal which needs removing drying/ cleaning and resealing to (depending on type of roof on your van) roof joints needing sealing :Doh: Best tocheck where the water has got in before we start to give you bad news and worrying you :winky:Will give better advise once we know what caused the problem :thumb: but it needs sorting sooner rather than later- try a temp seal with gaffer tape or something because they have forcast more rain,or even get up there and dry reseal around the edges of roof light.You can always clean it up later if you make a mess.Not ideal but better to stop water getting in :Smile:
terry
edit Snap John as I was typing hehee
edit 2 if unsure dry/gaffer tape the joints across the roof as well -noticed you have an Eldiss so assume you have ali roof
669
368
Bury St Edmunds
1 year on and loving it!
Thank heavens for gaffa tape! Mine's festooned with the stuff, until I get her in the dry and fix things! Most of it is 'just in case'.
Movan so hope you manage to get up there and get yourself sorted! I hate water leaks - they are such a worry.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Don't panic. Oh, you have.
Fingers crossed, with the weather we've been having, you could have got a local lake round your roof-light that allowed water to rise to the vent level.
Mine will do this if there is enough rain, it's at an odd angle and the wind blows hard. It's only done it twice in many years.
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Hekis are prone to leaking as they are so large, and the body flexes as you drive.
You need to get a temporary seal around as soon as possible.
Don't use Gaffa, as it won't last long. Use some UV Stable repair tape - looks like a large roll of sellotape. That will cure for now, and last until spring. If you can, park you van on an angle to aid water flowing off the roof.
Here you go - http://groceries.asda.com/asda-esto...e=Products&headerVersion=v1&_requestid=351005
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Hi Joy,
Definately park it on an angle so the rain will not settle on the roof and leak in,
Drive it up some levellers or a plank with bricks underneath and get some heating going inside to dry it out.
Good luck
Peter
movan
movan
21,492
120,753
Moving around
Burstner
since07
:thumb:Thank you all so much for your replies. I am phoning up today for an appointment to have it all sealed round the window. Wish I could save money by doing it myself but maybe I will in the future progress to this.... but you have put my mind at rest ... so not panicking now. Thank you.:thumb: Joy
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Insist it is removed and resealed - no bodging!
When it has been done, and you are home, remove the grill around the outside, as it will aid the frame drying out.
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
DO NOT go to the place the penguin went to to get his motorhome checked he took his van in as he had an oil leak ,the workshop man said go a walk around the town and come back in an hour.He went in the icecream parlour and had a big glass full while he waited and made his way back to the workshop.The workshop man said to the penguin"you have blown a seal" the penguin said " its icecream honest" as he furiously wiped his mouth.
hdvrod
859
733
devon
coachbuilt
since jan 2011
I keep some of this in The MH in case of emergencies,but can be a bugger to get off,when you do permanent fix.
Link Removed
Daveo2006
1,164
998
kent
Apache 700
3 years
Ive also bought a tube of Carafax non drying bedding sealant which would be a good temporary fix but easy enough to clean off for a repair.Can you not stick your head out of the rooflight to have a nose around at the mastic joints?
Hayleylulu
Banned
Feb 17, 2008
5,326
3,827
Full timing in the van
Fiat decato
8years
You carnt ask a lady to that man:
