HELP, door [not cupboard] stay wanted
Discussion in 'Motorhome Chat' started by cudleydudley, Apr 16, 2012.
  1. cudleydudley
    cudleydudley Read Only Funster
    May 5, 2008
    63
    21
    cheshunt herts
    HELP PLEASE my tribute t-625 m/home door, has a "stay" which allows it to open and "stay" at aprox
    180 degrees, [this stops it hitting the side of the van] what i want is a "stay" that will stop
    90 degrees, as well, so when the awning is up, the door will not, hit the awning wall.
    note there are a lot of window/cupboard stays, but they, are not the right thing and to flimsy
    for a door when the wind is blowing :Doh::helpsos:
    george = cudleydudley
  2. Dreamchaserrv
    Dreamchaserrv Read Only Funster
    Jan 31, 2008
    110
    10
    Wherever we park
    Hi George, Go down to your local scrap yard and get a gas strutt and brackets off a hatch back like a Corsa .
    Position brackets on inside of hatch where required to hold it at 90 degrees.
    The strutts are strong enough to hold against wind.:thumb:
  3. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    another alternative again from the scrap yard is a piece of seatbelt.
    if you use press studs to fix it then you have the option of holding the door at any position you like. and use a bungy cord to hold it open.
  4. cudleydudley
    May 5, 2008
    63
    21
    cheshunt herts
    thanks lads any more ideas, the old seat belt looks best at this time, but would press studs hold it ?
    what are those "things" called where they go through a slot in the webbing, and the "thing" twists to go across the slot to hold it to the door/wall.
    but as anyone got another answer??
  5. aba
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    the press studs should hold if they are pulling sideways another option is velcro.
    or maybe you could get hold of a wire type rear van door stay off a vauxhall combo or escort van.
  6. Allegro83
    Allegro83 Read Only Funster
    Jul 20, 2010
    67
    42
    Balfron, Stirling
    Or perhaps an eyelet and turn button would work.
    Jan
