Help! Dashboard battery light on with engine off (2 Viewers)
greggzy001
32
4
Aberdeen
Chausson Flash 03
Since 2011
Sorry for the long post but need a bit of help and thought it best to give you the full story.....right here goes:
I have a 1995 Swift Kontiki 640 on a Peugeot 2.5tdi base. The van started first time on Friday and drove fine down to St.Andrews (65 miles approx). Parked up on site, switched engine off but the red battery light on the dash illuminated. :cry: Restarted engine, the light turned off, I checked van battery voltage when running and got around 13.8V ish. Switched engine off again but the light came on again. Checked van battery voltage with engine off and it was 12.8V something.... Left the van 10 minutes but the light remained on. Rather than chancing a flat battery on restart I disconnected the van battery -ve.....guess what, dashboard battery light was still on! :Angry: Checked leisure battery voltage with engine off and it was around 12.6V. Pulled fuse out of the leisure battery circuit and the dash battery light went out.
Ready for departing this morning, I put the fuse back into the leisure circuit, dash light remained off, reconnected van battery -ve and light came on again but the van started first time and the light went out. Nice drive back to Aberdeen but again, when parking up and turning the engine off, the red battery dash light came back on! I've disconnected the batts again until I can take a look tomorrow.
Other info: Last week I removed the van battery tray as it was very rusty, it fell apart in my hand and some rusty crud fell down into the engine bay. I removed as much debris as I could and cleaned up and re installed the repainted tray carefully so as to not disturb the wiring in that area.
I checked both earth straps for corrosion and condition but they are fine
Sometimes when starting (usually when warm) when turning the key to start after the glow light goes off, I hear a single click of a relay but the van doesn't start but it always starts on the second attempt.
Apart from the obvious advice of "take it to a garage" has anyone had any similar experience which could help me pinpoint the problem before I heed the obvious advice?
Thanks in advance:thumb:
Gregg
greggzy001
greggzy001
32
4
Aberdeen
Chausson Flash 03
Since 2011
Thanks pappajohn, i'll investigate tomorrow.......fingers crossed. Would that cause the intermittent non starting condition also?
Regards
Gregg:thumb:
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
diode in the alternator gone tit's up:Sad: replace alternator:thumb:
43,344
49,545
Just one thing Chris.
with the engine battery disconnected the light would go off anyway...no power source, no light.
with a stuck relay the power is still present with the engine off and battery disconnected...the relay will bypass the ign circuit and backfeed the alternator....just the same as turning on the ign but not starting the engine with the engine battery connected.
greggzy001
greggzy001
32
4
Aberdeen
Chausson Flash 03
Since 2011
Thanks guys.... So i guess its best case: split charge relay and worst case new alternator (or both). Regards Gregg
43,344
49,545
Regards
Gregg:thumb:
No...but neither would a faulty alternator.
that sounds like a faulty ign switch, starter solenoid or dirty commutator in the starter motor
greggzy001
greggzy001
32
4
Aberdeen
Chausson Flash 03
Since 2011
Thanks pappajohn, i did consider the starter motor or ig sw. Ill get the battery light fixed first and continue the investigation into the starting problem.
Ill try the relay tomorrow
Thanks again for your help
Gregg
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
the big thick red/brown wire that is connected to the allternator is a constent live, the small wire is the ignition feed wire or exciter wire,when a diode goes down in the rectifier pack it will send 12v up the ignition wire putting the light on even when the ignition is off,(sometimes)
easy way to test is with a lamp tester disconect the small wire on the alternator leaving the red/brown wire in place,put one end of lamp tester to the small wire connector on the alt and the other end to earth if it lights up the alt is kaput.
greggzy001
greggzy001
32
4
Aberdeen
Chausson Flash 03
Since 2011
Thanks for this info chris, obviously for cost and ease, ill check the split charge relay first then if the problem is not solved, ill start on the alternator side.
Regards
Gregg::bigsmile:
17,637
43,375
diode failure is not neccessarily a case for a new alternator. A local firm will refurbish it much cheaper, the same with starter motors.
greggzy001
greggzy001
32
4
Aberdeen
Chausson Flash 03
Since 2011
Pappajohn, thanks for the help and advice with my battery light problem last night. Can you identify the split charge relay on the pic attached? I believe it to be the one indicated with the red line as it is fed directly off of the van +ve and is fused. Are relplacements readily available or is it a motorhome garage job? I think one of the two 'standard looking relays' marked with blue lines is for the fridge but i'm not sure what the other is for.
Regards
Gregg
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
the 2 marked with blue lines! one is the split charge relay the other is the fridge relay,the one marked red ignore its not a relay.:Smile:
greggzy001
greggzy001
32
4
Aberdeen
Chausson Flash 03
Since 2011
Great guys! Thanks for your help, ill pull the relays tomorrow and test. Hopefully it'll just be the relay.
Regards
Gregg
43,344
49,545
Chris is correct...and the same layout and position as on my old kontiki.
from memory both relays are identical so you should be able to simply swap them and see if it cures the problem.
if it is stuck on then the fridge will switch to 12v without ignition turned on.
replacement would be a normal 4 pin 30amp automotive relay...no need to pay a premium for one marked 'motorhome split charge relay'
greggzy001
greggzy001
32
4
Aberdeen
Chausson Flash 03
Since 2011
Thanks again for your help all! Ill try swapping the relays tomorrow and hopefully this will solve the problem.
Cheers
Gregg!
greggzy001
greggzy001
32
4
Aberdeen
Chausson Flash 03
Since 2011
Right guys, problem with my battery light is now diagnosed. I tried swapping the fridge and split charge relays but the battery light remained on. Whilst in a 'fiddling panic' I nudged the chunky wire running from the split charge relay connection (I think)to the alternator. This is protected by a rubber sheath and contains a thinner wire also which I believe runs to the dashboard battery light. When 'fiddling' ie tugging the wire, the split charge relay clicked on and off. On closer inspection it looks like the rubber sheath has been rubbing on the back of the engine block and has worn through. Ill pull the sheath off at the weekend and look for the short in either the thick, or thin wire and replace as necessary. Thanks again for all of the help and advice, without which, I would have probably put the van into a garage to be diagnosed.
Best regards
Gregg :thumb:
greggzy001
greggzy001
32
4
Aberdeen
Chausson Flash 03
Since 2011
Agreed! Without you pinpointing the circuit, I wouldn't have known where to start! :ROFLMAO:
Thanks again
Gregg
