Help.....damaged roof (3 Viewers)
Nov 6, 2013
3,201
229,849
East Sussex
Hymer B574DL
Since 2011 (tugger for 20 before that)
Had a bit of a mishap yesterday and caught the bottom of a shop sign on the roof of the MoHo :swear:
Never having undertaken GRP repairs before I was wondering if any of you good folk can give me some tips on how to go about it.
If I can upload the pics you will see that it has punctured the skin (temporarily repaired with Gaffa tape.
I would appreciate any advice.......even if it is "take it to a dealer" ;)
John.
Apr 13, 2012
5,545
18,776
Mobilvetta Euroyacht
1996, then break 'til 2011
Simple enough repair, if you feel up to it : remove any loose bits, 'key' area, fill ( not too much) with car body filler, rub down, prime and paint.
Hardest thing will be matching the colour (hundreds of whites/greys
Otherwise try a local bodyshop (not the Bodyshop :LOL:) - shouldn't cost a lot for a professional finish(y)
DuxDeluxe
14,659
72,818
Planet Zog
A woosh bang van
Unlucky........ Sorry to hear of that.
The positive side is that it is in an area that is not easy to see and looks to be reasonably easy to repair for anyone who can do a bit of good DIY. Also, it does not look structural though that depends on how Autotrail Motorhomes are built.
It's probably a good idea to google "GRP repairs" and see if you think you can DIY. Also have a look around for a local boat repairer or similar. A dealer will probably just send it to a specialist anyway. Even a local car repair place could probably do it. Others will have much better ideas, best of luck anyway and keep us posted on progress.
Edit - just seen Burstner's reply
Baycott
Nov 6, 2013
3,201
229,849
East Sussex
Hymer B574DL
Thanks to you all for the advice.
I'm not bad with DIY so will give it a go.
That looks great Bungy(y)
Thanks for the link
John
Feb 24, 2013
13,090
101,511
Bolsover, Derbyshire
Hymer S800
not long enough
I did similar damage to a car bumper once, looked like I had written can off at first glance :(
Mended and repainted in a day, looked as good as new, I don't do and for what it cost me I would not even try to mend myself, but mine would have been more visible than yours
The key thing is not to ask your MH dealer to mend it, do as suggested above, boat yard, car body shop, bumper specialists
Hopefully nowhere near as bad as you first thought (y)
Jan 24, 2010
2,440
4,850
Adria Twin
Thanks for the link
John
your welcome...youre not the first and sure as hell wont be the last to have a minor alteration like that!!...
Edit - meant to add, whilst your waiting to get it done, give it a good wipe down with white spirtit/meths etc and get it taped up to stop moisture getting in - given where it is you need to make sure its sealed as you might end up sealing it in!! (been there done that)
Nov 18, 2011
11,862
43,073
Planet Earth
A van
Over 25 year's
that a very esay repare if you know how to sand something down then get the gel cote code put on the gell cote allow to dry rub down with wet and dry finishing wit the finest you can get then spray with Laker that how I would do it
my fix it meet next year I am doing a body reaper including fibre glass repair got lods to do on my van but haven had time with fixing engine and using it
Sep 11, 2012
99
65
Cheltenham
Low profile
When carrying out grp works the existing top gel coat needs to be removed from the area that needs repair. Use a small grinder or sander and get right back to the resin base.then you can apply a matting and resin,sand down and apply a gel coat then paint to match.always clean down at each stage with acetone,if you try to gel coat onto gel coat it will probably peal off in a few weeks.being a grp roof installer we make repairs as part of our works if you were closer I could have given you the correct resins and matting to carry out the works.
Baycott
Nov 6, 2013
3,201
229,849
East Sussex
Hymer B574DL
Thanks again Bungy.
I taped it up the same day......just as well I did as we had a terrific storm that night.
Thanks Bill.
I only wish your repair was as simple as mine seems to be.
Best of luck with yours. (y)
Thanks Zajacp.
Will bear all that in mind.
Apr 13, 2012
5,545
18,776
Nothing worse than a bad repair - especially on a motorhome - I'd take it to Johns Cross as they are local - no harm getting a quote
