Hello I wonder if you nice people can answer two questions (1 Viewer)
Sep 10, 2011
231
218
West Midlands
Laika Ecovip 309
since 2011 but years in a caravan
Hello I wonder if you nice people can answer two questions I have
Question 1 is I have a SMEV oven and I have not found out how to light it I cant see a electric switch, there is a switch for the light and one for a rotisserie but not one to light it.
This seems strange as there is on for the hob and that works fine
Question two
I have a 240v switch above my wardrobe that does nothing, below the wardrobe is the heating system.
It looks like the type that should light when turned on but it does not light up and I don’t know what it does, see attached photo.
Thanks for any help.
John
DESCO
2,646
266
London
low profile
18 years +12 years tugging
Re switch can.t help
Re oven lighting may have to be lit with flame as they do not all have electronic ignition. Some times it is turn on the gas and hold in till going. This can apply even if the rest ignites by electronic ignition, has caught me out before.
John-Laika
Sep 10, 2011
231
218
West Midlands
Laika Ecovip 309
Thanks for the reply Dave I guess I will just have to take some matched or but one of the auto gas lighter with the lomg neck you can get
scotjimland
2,335
10,104
A Woosh bang
Never seen an oven with an auto igniter .. not to say there aren't any .. Our SMEV had to be lit using a naked flame.. all have to have the door open, basically this is for safety.. if you were to try and light with the door closed and there was a tiny bit of gas in the oven..... :Eeek:
John-Laika
Sep 10, 2011
231
218
West Midlands
Laika Ecovip 309
Very good point Jim never thought of that,Doh:Blush:
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
More than one Jim, ours also has an electronic lighter & can be lit with the oven door closed.
After over 4 years never had a problem with it :thumb: Cannot remember the make but have seen many vans with the same model so it must be the way they do them now.
There must be ventilation where the air can get in or the flame wouldn't burn so there is probably a way at the rear somewhere that would let out any residual gas out & I can see a gas drop hole in the floor directly underneath the oven.
scotjimland
2,335
10,104
A Woosh bang
I stand corrected .. must be using non explosive gas now :roflmto:
rob kinnear
175
31
Swansea
Hi Top
1 year 10 years tugger
WE have a Smev cooker with electronic ignition in oven. We have found by trial and error that it will not ignite if the hob lid is fully vertical and the ignition is from the same switch as the hob I hope this helps
Rob
chrisgreen
Jul 26, 2009
5,980
12,332
england
c class
since 2004
Rob
our's is the same:thumb:
ciderman
380
416
derbyshire
Hymer 754
4 years old
my smev lights with door open fully and turn +push in to activate the ignitor and gas valve if it dosn't spark or light with naked flame then suspect the 12v is not connected to the oven:Smile:
callumwa
4,110
4,480
Tyne & Wear, sometimes..
4 yrs +, 30+ yrs motorbike touring
Ours also has electronic ignition. Turn it and push it in for, clickety click as it sparkety sparks..
I always do it with the door open that way I can see clearly when it ignites, never tried it with the door shut, because if it does not spark straight away..........:Eeek:
Only ever used the oven rarely for savoury pastries, pies, etc and occasionally reheating Curries and Chinese. Now I have fitted the microwave, guess we will use it even less, if at all.
43,330
49,446
not sure, but these push knob automatic sparky things may be battery powered....and the batteries are dead !
one or two D type dry batteries in a holder somewhere under the oven.
MHVirgins
3,889
3,158
South of Scotland
March 2011
Yes, we also have a Thetford oven in ours, like calumwa's it's "clickety click, sparkety spark"! Bingo!
We light it with the door closed and can see whether it ignites with the auto ignitor "pressy down button":thumb:
Probably all the newer vans have these nowadays......there appears to be vents etc at the back, so no problems with that.
We have had a problem trying to get the fridge to ignite when we switch it over to "gas mode" though:Blush: maybe just not got the hang of this yet though.
Heyupluv
3,862
1,593
France,
touring many years..42+
FIRSTLY YOU MUST HAVE YOUR HAVE YOUR 12V SWITCHED ON.... the 12v that runs all interior and exterior electrical items in the Motorhome, for lighting ,water,etc,......this is to power the igniter
Both of our Motorhomes have / had igniters.....The last van was a SMEV oven...( the wife thinks! as most of the time you do automatically)....you turned the control knob to a set start position holding the knob down, the press the electronic igniter switch(near the control knob) until the oven is lit...still holding the knob down for a few seconds until the gas sensor is hot and activated (or it will shut down again ) then turn to the desired setting of heat required.....
On the new motorhome as you are turning switch holding the switch down it activates the igniter and lights the oven
Mel
John-Laika
Sep 10, 2011
231
218
West Midlands
Laika Ecovip 309
Rob
That’s interesting but our hob is some distance from the oven so I could not hold the knob in on the oven while operating the clickey switch, I know its not called that but I like that name better.
Thanks for all your replies,:thumb: I will have fun trying all your suggestions and if they don’t work buy a gas ligter.
John-Laika
Sep 10, 2011
231
218
West Midlands
Laika Ecovip 309
Mel
Thanks Mel but there is no electronic igniter switch near the control knob the only electronic igniter switch is on the hob and that is no where near the oven.
Heyupluv
3,862
1,593
France,
Ours was the same the oven at /near top of one side of the Motorhome and the hob on the other side of the Motorhome a good distance away...
Also on our Smev oven there was a thin sheet steel plate at the top of the inside of the oven this needed, had to be pulled out when you did TOAST...this was to stop you closing the door on safety grounds...or so we was instructed our dealer:Eeek:
Mel
Heyupluv
3,862
1,593
France,
OK then try holding the switch down as you turn the knob BUT make sure the 12v is on:thumb:
Mel
a piece of info of smev ovens
Thermostat
Interior light
Electronic 12-volt ignition with safety ignition system
Easy to use and install
Easy-clean door and interior
Chimney connection
Heyupluv
3,862
1,593
France,
Mel
Thermostat
Interior light
Chimney connection
This was our Smev model FO391 GT-L ..(.the L was because it was left hand hinged )
all our control's was just inside the glass door...
Link Removed
Mel
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
there's always one aint there :roflmto:
bet you can't light it with the door closed.. :winky:
::bigsmile:Ours is a caprice full size cooker and the oven ignites after you press / turn and hold in the knob-then you press igniter button :thumb: -with or without door open :Smile:
terry
Steveutwg
41
26
Rushenden, Kent
Bessacarr 560
25 years
Just a thought, have you tied to see if the hob igniter, will light the oven? As for the switch, try following the wires back, too see where they go, that should give you an idea.
Good luck steve
MHVirgins
3,889
3,158
South of Scotland
March 2011
Broken Link Removed
Hi! What's the latest on your neighbour and the van in the driveway?
Just wondered when we read this recent post:Smile:
Margaret & Bill
43,330
49,446
Mel
just seen this Mel, and the plate is usually a heat deflector/diverter to stop you melting the cooker control knobs when grilling. :thumb:
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Come late to this thread but our Smev oven just has the one knob which you turn to the temperature required and hold the knob in to ignite. The knob also falls off while travelling so we usually remove it so it doesn't get lost. :RollEyes:
John-Laika
Sep 10, 2011
231
218
West Midlands
Laika Ecovip 309
Broken Link Removed
Margaret & Bill
Margaret & Bill
I have managed to park it infront of our garage its very tight and not easy to do but it keeps him quite
Regards
John
