Heavy duty clutch (1 Viewer)
barrywi
120
28
Cumbria
C class
I am a Newbie to motorhomes but have caravaned for years
The clutch on my 2008 3 litre m / h works fine but in reverse it is never happy. I was just wondering if anyone makes an uprated clutch for the Peugeot / Fiat base?
Bartyfixedit
330
566
Maidstone Kent
Self Build Ducato L4H3
Since 1987
The problem on the Fiat is that reverse gear is ridiculously too high a ratio. I reckon reverse is probably similar to 2nd gear hence reversing up hill will always be a problem. I don't think a heavy duty clutch will make any difference. Sorry.
TheBig1
17,630
43,279
there is a kit about to convert the dual mass flywheel to a heavy duty clutch. however it allows more vibration and strain on the gearbox
barrywi
barrywi
120
28
Cumbria
C class
No need to apologise, not your fault. We had to reverse up the ramp onto the ferry from Hull to Rotterdam because of the way they loaded the boat and there was quite a bit of juddering. It is stupid that the gearing is so high, maybe van drivers like to go go fast in reverse. No problem here in Holland where we are on holiday because it is all flat and we have hired a small car to get around.
barrywi
barrywi
120
28
Cumbria
C class
I did not realise the Peugeot/Fiat had a dual mass flywheel. I hate them. My Peugeot 407 Diesel had one and I had to have two fitted at very low mileages. One they paid for under warranty, but I had to fight to get them to pay anything towards the second one. All happened below 30000 miles. I have had Peugeots in the past that had clutches that lasted 100000 miles even towing a caravan. Progress is over rated!
Sep 26, 2013
4,169
5,155
Market Rasen
Self Build
Since 2003
Sounds like your van has never had the fix. Being a 3 litre it is obviously a Fiat and 2008 vans were candidates for the judder although most vans fixed were the 2.3 versions.
As you may be aware the fix included a lower reverse gear, new clutch and engine mountings.
Might be worth asking if it can still be done.
Mike
PP Bear
7,807
28,779
Kent, UK
Auto Trail Dakota SE
It's because it's Italian, always did go faster backwards, just like their tanks, 1 forward, 5 reverse. Same with their guns, fired once, dropped once :rofl:
My Ducatos the same, I only noticed when I tried to reverse up my levelling ramps once, instead or driving forwards up them. Never again if I can help it :)
barrywi
barrywi
120
28
Cumbria
C class
Thanks Mike I will ask at my local Peugeot garage, I bet they want money for the update though!
Sep 26, 2013
4,169
5,155
Market Rasen
Self Build
Since 2003
If it's the Fiat 3 litre then it needs to be a Fiat garage. When the fix was done the cost was around £1250 according to the garage who did our 2008 Burstner .
Mike
Jun 30, 2010
7,924
27,229
Cornwall
1992 VW Auto sleeper Mono
Since 2005 this time
Fiat Ducattos also have a PLASTIC Clutch Pedal! (mk2s anyway) Mine gave way in the middle of Dartmoor!
Dec 30, 2008
1,106
2,126
Cheshire
since Dec 2008 after 10 years caravanning
Sounds like your van has neverin the gehad the fix. Being a 3 litre it is obviously a Fiat and 2008 vans were candidates for the judder although most vans fixed were the 2.3 versions.
Mike
Mike, a lower gear was never an option as the (cog) gear was too big to fit in the gear box, the other mods your spot on mate,
Eric
Sep 26, 2013
4,169
5,155
Market Rasen
Self Build
Since 2003
Eric
According to all the information at the time the fix included a new lower reversing gear.
Mike
TheBig1
17,630
43,279
Clutch !.....remind me what that is !
the part on the end of the engines final drive that you can often smell burning in supermarket carparks. old farts revving their vehicle engines high and then cant find the biting point:rofl:
Dec 30, 2008
1,106
2,126
Cheshire
Mike
I have the 2.3 Mike It went into fiat professional twice, 1st time it had new engine mountings, 2nd time it had new clutch, supposedly heavy duty but no lower gear, I was told that was,nt an option, and my motorhome is still rubbish when reversing.
Eric
Sep 26, 2013
4,169
5,155
Market Rasen
Self Build
Since 2003
Eric
Our 2008 Burstner was done a few months after we bought it and I'm fairly certain that the original fix included a lower reverse gear.
There was certainly a difference after it was done and reversing was a lot better and it also sounded different.
Mike
Dec 30, 2008
1,106
2,126
Cheshire
Mike
Hope you are right mike, Ive learned to live with mine, its not a problem as we dont do that much reversing, lol
Eric
