Heat, or lack of it again! (1 Viewer)
Bushtrekker
253
120
Cannock, Staffs
Hymer Tramp
Second time around.
I rang a couple of Truma authorised service people today, without a result, but the second one suggested I rang the Truma technical support people direct. When I told them I had a Trumatic SL 3002 they said we've never made one with that number, so I asked them to hang on while I grabbed the manual and confirmed that was what I had. They suggested I email some pictures which I did, including one which clearly shows SL3002 on the front cover. I had an email back asking me to send them a phone number, so am now waiting for a call back:Sad:
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
does the heater get hot with the fan switched off ???
i do know that on some of the older sb1800 type there is a gas feed pipe on the heater that rusts away externally so may become porous and reduce gas pressure to the main burner.
weather the one you have would suffer this problem i don't really know
just another thought if you light all the gas rings 1 after another on the cooker does the flame drop as you light more as this could point to a failing regulator
43,329
49,445
how very strange they dont know the model........from the Truma website
see pages 5 and 6
http://dealer.truma.com/_anweisungen/Truma-Katalog/pdf_verzeichnis/30_000/sl_3002.pdf
callumwa
4,110
4,480
Tyne & Wear, sometimes..
4 yrs +, 30+ yrs motorbike touring
Maybe you have to start the conversation with the Truma technical support help desk like this...
"Ich habe ein Trumatic SL dreitausendzwei"......!
und dann vielleicht alles ist gut und alles ist klar......:winky:
43,329
49,445
this could be why they dont know the model......they arent old enough to remember it
Trumatic SL 3002 / 3
from year of manufacture 07/1981
until year of manufacture 05/1993
JJ
Mágica
May 1, 2008
19,259
48,046
Burstner Privilege T
over 50 years
I would suggest that the burner is partially blocked and therefore is not generating the required amount of heat... If only I was there I would like to try to sort it for you... I love those heaters...
Get it out here to Portugal... between us we will get it roaring away... (I have a couple of spare burners somewhere...)
JJ :Cool:
B
Bushtrekker
253
120
Cannock, Staffs
Hymer Tramp
Second time around.
Ongoing situation.
I've just turned the heating on and left a thermometer in the van to see what difference it made...three degrees. It looks increasingly as though the burner has partially burnt out and is not creating enough heat, but because of the start of the caravan season it's difficult to find someone to look at it immediately. As an interim measure I'm wondering whether I could run a fan heater on low off the site electrics?
TheBig1
17,630
43,279
a small oil filled electric radiator works well in a small to medium size van.
what you have described though sounds like a blocked or coroded gas jet. fairly simple to fix if your competent with tools
B
Bushtrekker
253
120
Cannock, Staffs
Hymer Tramp
Second time around.
Thanks, I'll have a look tomorrow.
I've been looking at prices for jets, but just discovered that a new heater is available online for £289, so i this goes through MOT OK I might get one fitted if I can't sort this one, as by the time I've paid for spares and labour it won't be far off that.
