Headlamp Bulbs Keep Popping (1 Viewer)
bernardfeay
613
1,191
Bolton
hymer exsis
10 years
My headlamp bulbs last for about 2 months and I can't figure it out. I don't touch the glass with my fingers; I've tried expensive and cheap bulbs.
Any clues or suggestions greatly appreciated.
Base vehicle is Fiat Ducato 2.3 jtd
Jaws
23,836
72,492
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
If you have a meter check the battery voltage
After a run, and before you turn off the van, get someone to hold the revs at approx 1500 to 2000 whilst you check the voltage across the battery
In the last couple of years I have found three vehicles where the alternator control regulator was pushing the voltage up to well over 15v.
Sep 10, 2013
1,187
18,711
Chelmsford Essex
Getting better
Many years ago I had a Hillman Minx, magic motor, paid all of £50.00 for it, complete with bench seat and all.
However it had a habit of the headlamps getting brighter and brighter the faster the car went, probably to a maximum of 65mph, then they would both blow, very exciting, sudden blackness.
Something to do with the Dynamo / voltage regulator, solved the problem......kept speed below 60mph!
Aug 18, 2014
23,786
133,728
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
My car does that normally as it has a 3phase/14volt alternator !:D
Jaws
23,836
72,492
Thetford Norfolk
C class, Chieftain
Yesss.. but not WELL over.. you def should not see higher than 15.2v across the battery !!
DanielFord
3,020
3,086
That was my immediate thought! Many moons ago I had a peugeot 104, that at some point had a dodgy alternator fitted, it popped headlamps all the time. When I put in the correct alternator with the correct regulator all was fine.
Sep 24, 2013
1,309
748
Norwich
Carthago A class
Since 2014
Had a VW Polo that did that a lot. Many happy memories of changing the bolt on regulator at the side of the road. Usually noticed it by the smell.
steviebouy
120
110
Pucklechurch, Bristol BS16 9SE, UK
Low Profile
Since July 2011!
Do all these lamps fail in the same way? I recall a lighting expert telling me that examination of the lamp may reveal the cause of its demise. I must say I hadn't ever given this much thought before but it made sense to me . We have all seen lamps where the glass envelope has become blackened or is coated with a black or silver substance.
Unfortunately it was so long ago that I have forgotten the symptoms that produce the results but from memory I think the white substance is caused by the envelope leaking the gas out and silvering is caused by a poor earth.
In all my years I have never heard this sort of information given by anyone else - perhaps it was all a deam?
Steve
Jaws
23,836
72,492
Thetford Norfolk
C class, Chieftain
A poor earth .. that would cause the voltage supplied to the bulb to drop not increase.
Apart from that, yes,, blackened glass means air has got in .. The xenon or argon gas is inert and as such has nothing to burn.
When air gets in there is something to burn and that will cause the smoke that forms the black deposit.
You often see this in an environment that has a vibratory component ..
The silvering is caused by excess voltage usually.. The filament simply burns up using its own material.. The tungsten literally eats its self and then melts and goes splat !
