have to stall engine (1 Viewer)
mick noe
Apr 14, 2009
638
539
near Boston Lincolnshire
low line
can anyone shed some light on a problem I have with 97 ducato 2.5 turbocat engine On a very irregular basis it will not turn off by ignition I have to stall it NOT NICE.:Sad:
43,331
49,460
sounds like the fuel shutoff selonoid on the fuel pump is sticking open.
ignition energizes and opens the selonoid, turning off closes it under spring pressure.
easy job to remove and clean it out.
JJ
Mágica
May 1, 2008
19,259
48,046
Burstner Privilege T
over 50 years
I expect Pappajohn's suggestion is the right one... so pay little heed to my story... but I had the same problem with my Iveco engine and it was caused by the spring in the solenoid actually breaking. The pieces went into the injector pump... you don't want to know anymore!!!:Sad:
I suggest getting it checked quickly...
JJ
American Dream
156
Lincoln
Yes The diesel Shut-off valve isn't closing properly.:thumb:
Had a similar problem with my previous motor.
43,331
49,460
usual fault with the selonoid is a total failure but then it wont start anyway 'cos it wont open.
could be dirt has found its way past the filter and stuck in the valve or just plain wear and tear on the valve.
scotjimland
2,335
10,105
A Woosh bang
Exactly what happened to mine John
For a few days the engine would run on for a minute or two before stopping..I put it down to a sticky fuel solenoid.. but stupidly didn't investigate until it was too late .. it literally fell apart, fortunately at a Spanish service area..
I collected the parts from the road and managed to re assemble but the connecting rod on the solenoid was badly worn and wouldn't re connect to the valve ... hard to explain.. anyway, I effected a repair, a bodge, I drilled the shaft and put a nail though it to hold both parts together and continued the journey home.. A backup plan was to attach a piece of wire and hold the valve open manually .. but the bodge held.
I bought a new valve and solenoid from Cummins when we got back the UK ... £325 ..
Moral .. don't ignore an obvious developing fault.
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Had the same problem with one of the boats engines, but you cant stall those !!
Fortunately they have a manual shutoff by pushing the solenoid rod down:thumb:
Peter
American Dream
156
Lincoln
Diesels on the boat eh Peter...:Cool:
Inboard or outboard...
The other way is to fit a fuel shut off valve...either manual or solenoid operated...in the fuel lines.
Any Pics?
43,331
49,460
much easier 'get around' Jim.....just remove the plunger from the valve and refit the selonoid....but you need to stall the motor every time.
east enough in 3rd or 4th gear.
did it a few times when doing breakdowns on ford diesels.
mick noe
mick noe
Apr 14, 2009
638
539
low line
where is valve is it something I could attack myself as he i'm not a bad hand at motors (old bikes and cars ) bye the bye thanks for the replys :thumb:
American Dream
156
Lincoln
Hi Mick.
Mine was on the diesel Injection pump body and had a single wire to it.
Do you have a workshop manual for the base vehicle?They are usually very good with schematic drawings/photographs.
It needs to be very near the pump to shut off the flow to the engine virtually instantaneuosly.
Good Luck.
Steve.
scotjimland
2,335
10,105
A Woosh bang
Problem wasn't stopping John
On the Cummins, the valve and solenoid are separate parts.. lose the solenoid and the valve closes by itself ..
besides, have you tried stalling an engine with an auto gearbox :roflmto:
motor roamin
May 23, 2010
1,541
792
Leicester
2 mins
Oh to go back to that bit of wire with a big knob on the end marked stop.:ROFLMAO::ROFLMAO::ROFLMAO:
Had the same problem on a Scania it saw the pump off as well £2,000 was the bill.
Aug 27, 2009
19,791
23,071
Hertfordshire
Van Conversion
40 years
This brings to mind some of the temporary bodge jobs I have made to get me home. Some years ago I left my throttle linkage on the motorway 200 miles from home. My bodge was to run a piece of string from the carb butterfly through the side window into the car so that I could control the throttle from inside the car using the string. It got me home but I had a grove cut into my hand from pulling the string.
