Habitation door
Discussion in 'Tech/Mech General' started by Zoophoo, Feb 16, 2012.
  1. Zoophoo
    Zoophoo Read Only Funster
    Jan 23, 2012
    13
    Wales
    Hi all,
    wonder if you could help.
    I have a six month old bessacarr e495 with a Hartol habitation door, which has just had the seal renewed under warranty (small piece torn away by lock when I picked it up). Trouble is, that after the seal was renewed (by local repair centre, which dealer arranged to save travel) , I had to slam the door to close it and have excessive noise from the door when travelling.
    On closer inspection of the door, I noticed the door was bowed inwards top and bottom by about 6mm, and that the top of the door on the lock side was flush with the frame, whilst the bottom of the door on the lock side is standing out proud by about 6mm. The hinged side of the door is flush with the frame top to bottom. This seems to suggest that the door is either warped or has been fitted out of true. I had never noticed it before, as I never had cause to examine the door that closely
    I went back to the dealer and was told that the bow was normal and that all doors were made like that, so that the top and bottom pulls in tightly when the door is locked, which just does not seem right. (Not had time to check other new motorhomes). The dealer made some adjustments and it now closes without slamming but I still have the noise from the door when travelling and the door is still proud of the frame at the bottom. I put a hose around the door and water poured in, so I have to ring dealer back again in the morning.
    So my question is this,
    Are habitation doors made bowed (I can't believe they are but may be wrong) and and has anyone else had similar problems?
    Thanks all,
    Zoophoo.
  2. Hayleylulu
    Hayleylulu Banned
    Feb 17, 2008
    5,391
    3,881
    Full timing in the van
    sounds like another one of brown hills to me
  3. Zoophoo
    Jan 23, 2012
    13
    Wales
    In fairness, it was not Brown Hills.
  4. Glynn
    Glynn Read Only Funster
    May 2, 2010
    163
    18
    Lancashire
    Sounds like they are fobbing you off with bullshit, no way should it be like that.
