Habitation door
Discussion in 'Motorhome Chat' started by gordoncbrown, Nov 6, 2011.
  1. gordoncbrown
    gordoncbrown Funster
    Oct 2, 2011
    837
    568
    Scotland
    Hi, the MH came with an extinguisher fitted, on the side of the overhead locker to the left of the door. The type that was fitted just hung on a holder but would fall off if not removed before driving. You can guess how I found that out. I had wondered what the little dents in the bottom 18" of the door were. The little dents don't looke much so not concerned about them. What is a bit more of a concern is the bottom of the door doesn't shut fully. It looks like having been hit a few times has bent it or the hinge slightly. Any advice on how to rectify this? Is it just a case of carefully knocking it back into shape?
    Gordon:thumb:
  2. Swiftroy1
    Swiftroy1 Read Only Funster
    Jan 3, 2010
    180
    172
    Bedfordshire
    Hi, the bottom of my habitation door fitted badly too. To rectify it, I removed the door from the hinges as they were only screwed. I then drilled the hinge rivets carefully from the frame and examined the hinges. I found that the bottom hinge had been bent slightly comparing it to the other hinge. This wasn't visible till I laid one over the other. I then bent the offending hinge straight and refitted them. The problem was solved. I hope this helps.
    Roy
  3. motorhomelover
    motorhomelover Banned
    Jul 28, 2010
    1,719
    613
    The world
    SOUNDS A LITTLE MORE THAN A DIY JOB :Eek!: not sure I COULD DO THAT :Eeek:
  4. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,954
    I think it could be a "feature" of some Explorer vans that the lower hinge is either mounted slightly wrongly or bends. Our hab door used to creak quite a bit and then, eventually, the hinge broke.
    I sourced a new hinge from Marcle Leisure and fixed it myself. Not as daunting a job as I first thought, thanks to advice from other Funsters. See This Thread from June last year.
  5. Touchwood
    Touchwood Funster
    Aug 23, 2011
    770
    736
    NE England
    Hi Gordon, I have the same door issue on my Avantgarde 400 RL (2002 so presumably pretty identical to yours)
    At the moment there is no actual gap, the door seals but the lower part is definitely not as snug as the upper. I'd be glad to hear of any solution you've found, have you tried removing and checking hinges as has been suggested?
    Mike
  6. Terry
    Terry Funster
    Dec 27, 2007
    10,808
    6,321
    South yorks
    Hi you can bend the hinges back using a block of wood and a hammer :thumb::Eeek:
    terry
  7. Touchwood
    Touchwood Funster
    Aug 23, 2011
    770
    736
    NE England
    Errm - for someone with my aptitude for DIY that sounds like a recipe for disaster - a bit like [ame="http://www.youtube.com/watch?v=8g_GeQR8fJo"]this[/ame] ?
  8. Terry
    Terry Funster
    Dec 27, 2007
    10,808
    6,321
    South yorks
    Hi TW you are not kidding me :BigGrin: it says you are a heating engineer -you know exactly how to yeld a hammer :Rofl1:
    terry
  9. Touchwood
    Touchwood Funster
    Aug 23, 2011
    770
    736
    NE England
    He He - maybe Terry - but in my book a hammer (or engineer's reciprocating tolerance adjuster, to give it its technical name) is for breaking things, not fixing 'em! :Wink:
  10. gordoncbrown
    Oct 2, 2011
    837
    568
    Scotland
    Looking good. Tried a bit of gentle persuasion and the hinge side is spot on. Still a bit out somewhere but looking at the door it looks. Bit off true after all the bumps with the extinguisher. Next step is to tackle that.:thumb:
