Habitation clock (1 Viewer)
Nov 17, 2012
1,930
2,614
WEST SUSSEX
HYMER B SL 674
SINCE 2005
The battery clock that snuggly fits into the control panel above the habitation door of our 2019 B674 SL has stopped working (yes changed the battery!). As it is held in position simply by the tight fit,diameter of the rear mechanism, I need an exact replacement. Cannot wait 6 months for Hymer to respond any thoughts? Actually will seem like longer as the clock doesn’t work! Thank you and apologies it’s not such a hardship as other issues for some on here.
Lenny HB
53,632
150,743
On the coast in West Sussex
Hymer B678 DL
I take it is the same as ours a round one with a black dial.
I suspect the mechanism is a standard Chinese one so if you can find something similar you maybe able to change the mechanism.
Feb 24, 2013
13,109
101,575
Bolsover, Derbyshire
Hymer S800
not long enough
Mine broke and I found a replacement from Brownhills from their Hymer stock
I didn’t fit 🙁 wrong size, returned and got full credit
Ordered one from TW , during my headlamp issue, they tried to give me exactly same wrong one that Brownhills had
I pointed out the size difference, they still insisted on trying to fit it, TW queried with Hymer Who denied it was wrong size 🤣
It also has different graphics and isn’t even Hymer branded
We now have a clock that’s only right twice a day but at least fits 👍
Yet another spare part that Hymer can’t supply despite still being fitted up till a few years back 🙁
Feb 24, 2013
13,109
101,575
Hymer S800
not long enough
I thought that, but the front is glued on, remove the mechanism the hands fall off 🤔 and are stuck inside
Edit I broke the plastic front trying to remove it, gave up looking for a new movement then
Kim H
547
1,709
Lancashire
Hymer S800
Since 2011
David,
We replace our Hydrometer, we got ours from the ever helpful Chris at Reliance. Just supplied him the van serial number.
Anthony
Feb 18, 2017
4,134
8,016
Greenwich, London, UK
Hymer MLT 570
I think you will find those clocks are a fairly standard size.
An ebay search or onto a few specialised clock sites should get you a replacement.
(I replaced the innards on my father in laws electric clock a few years back, it took a bit of searching for the parts, but found it in the end. Perhaps see if you can find the manufacturer of the original clock)
Oct 13, 2016
1,053
897
Grays - Essex - UK
Mercedes Hymer B680
Been moho’ing for a time now
checkout 12v 52mm clock on ebay, there's loads on there
pandas
Nov 17, 2012
1,930
2,614
WEST SUSSEX
HYMER B SL 674
SINCE 2005
That was easy - all sorted now - not. Travelworld have just quoted £154 including delivery - wow. Now I am just wondering why I would be tempted to buy a replacement for something that broke just outside the warranty period? Difficult question to answer! I think they are about £10 tops without the Hymer branding.
May 18, 2019
22
19
David,
Anthony
Would you be able to send me that guys number...
i think it may prove useful in the future... i think my hydro' may need replacing..
thanks in advance
Paul
Minxy
32,689
66,706
E Yorks
Carthago Compactline
You could do what hubby did to our lounge clock on Saturday ...
pandas
Nov 17, 2012
1,930
2,614
WEST SUSSEX
HYMER B SL 674
SINCE 2005
Now that’s odd. Pulled out the tight fitting clock from the fascia panel to double check the measurements- dropped it. Bits flew all over the place. Put it back together Replaced the battery and….it works perfectly and it’s not even Halloween!
Minxy
32,689
66,706
E Yorks
Not a 'method' of repair I'd suggest but it obviously worked! :giggle:
