grill problem (1 Viewer)
Oct 24, 2011
195
78
shropshire
a class I think
10 months
The grill lights and run for a short while then goes out. Any suggestions on what is wrong and is it a dealer job.
Mike
Jul 29, 2013
9,071
18,539
Salisbury
Hymer B678DL A class
since 2011
Ours had a problem from brand new it would not stay alight the dealer had to change the the burner something to do with a regulator on it was nothing to do with oiling though the grill had never been used and the main regulator was only 12 months old.:groan:
scotjimland
2,335
10,104
A Woosh bang
Was it ok in the past ? Is the flame still strong with a blue tip ?
If so, check the thermocouple tip is in the hot part of the flame.. adjust if required .. if ok then check the thermocouple connection ..
if that's ok then the thermocouple may need replacing.
If flame weak then it may be a partially blocked jet, clean using a jet cleaning wire, or replace, the size is marked on the jet..IIRC you need a 7mm socket to remove the jet.
or as suggested a faulty regulator.
Jul 29, 2013
9,071
18,539
Salisbury
since 2011
Yes I am pretty sure ours was the thermo coupling and had to be replaced on a brand new Autotrail Tracker!
All works now though.
