Good customer service, AGAIN ! ! (1 Viewer)
Jun 17, 2012
2,933
9,932
North Essex
Autotrail Delaware
>12 but <13
I recently mentioned what good service I got from Garmin. Now Sergent Electrical are up for an award.
I rang them to enquire why leisure battery not charging from alternator but did on EHU.
The techie, DAN HOWLETT patiently listened and advised that this was not a PSU problem but a fuse or relay under the black cover under the bonnet.
He sent me a circuit diagram purely with the appropriate relay harness shown and hey presto, fuse blown.
Engine started and charging at the leisure battery, a nice 14.4 volts.
Well done Sargent and Dan.
I've been directed to solar panels by a friend. They are from BIMBLE INN, http://www.bimbleinn.com/, check out the prices.
Hopefully I'll be writing a good report for them, my friend is well chuffed.
Gunner29
836
610
Plymouth
Low Profile
good customer service NOT
the CS from Anglian on our conservatory is abysmal.
Auto Sleepers No problem
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
wow how big is your motorhome with a conservatory:ROFLMAO:
Deckard
513
469
Lancashire
...looking
Noob
I have been looking at those very panels - be very interested to know how they work out for you....:thumb:
Larby
Jun 17, 2012
2,933
9,932
North Essex
Autotrail Delaware
>12 but <13
My friend as I said is chuffed with his. He went for the 12v 170w panel and the MPPT charge controller at £155.80 plus £30 pp.
I have measured the roof and it will fit between all the clutter up there, just!
Now considering how to secure, he has screwed brackets to the roof as well as using Sikaflex.
Larby
Jun 17, 2012
2,933
9,932
North Essex
Autotrail Delaware
>12 but <13
Bought the "package deal" of 20 amp MPPT controller and the 170 watt panel.
The panel arrived within the week and the courier rang a few days before to confirm delivery between 2:30 and 4:30. Sure enough they did.
Controller was delayed as supplier was involved with Glastonbury. To be fair he did send out as promised (by a chase up email) immediately after getting home.
The delay did give me time to install panel and route cables.
You get panel and a few inches of cut off cable, I took this to an electrical wholesaler and got some of equivalent spec.
Panel is screwed with stainless steel self-tappers to plastic corner supports, then attached to roof with Sikaflex 512. The standard cross-bar on the roof was exactly right to hold down front and another (not shown) now holds down the back.
Controller is now installed and is now topping up leisure battery.
The package works out quite well if you check out the price of the controller elsewhere
