Getting into a Sargent EC200 control unit (1 Viewer)
Jerrymjj
100
27
Alton Hants
Autotrail Tracker SE
Newbie!
I want to wire in a new 12v supply for a television that I have moved from one side of the van to the other. (Autotrail Tracker SE 2006). According to the wiring diagram for the control unit there is a spare unused terminal.
How on earth does one get into the unit? It is a sealed metal box as far as I can feel, front and back and is fed a huge number of wires through a similarly sealed wooden box that it stand on. The unit appears to be riveted together. Any advice gratefully received.
Jerry
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Either take it straight from the liesure battery with its own fuse or take it from the back of the existing 12 volt socket
Nov 5, 2013
3,103
97,825
Shropshire
Carthago chic e-line
Since 2013
Give Sargents a ring in the morning they will point you in the right direction and tell you the right size wire to use.Most helpful people I've spoken to in the 18mths since we've had our 2010 Autotrail. Richard
Techno
Jul 28, 2010
15,475
20,756
May 2010
Pin 2 on the output is marked as spare. I would take that to mean it is an unused pin and that it is not wired nor fused.
The yellow/white on pin 10 goes to your 12 volt socket or sockets and only fused at 10 amps.
As you will know there are 8 fuses and all are spoken for, there isn't a spare fuse for an unused output
