ger box problem (2 Viewers)
Dec 6, 2011
11,601
25,455
South Wales
Coach built Adria
you mean you wiggle the stick and can feel no engagement? ( no pun intended):Doh: sounds as if a part of the linkage has detached itself.
Wildbill
Nov 18, 2011
11,862
43,069
Planet Earth
A van
Over 25 year's
after a bit i manged to get 4th then 2nd it just wont engage proper could it be frozen? it was ok last week end it hazen been the smothest sins i got it cluch has got plenty on it
43,337
49,538
Could be if its a Ducato base.
some had problems with water running off the screen into the gearbox linkage spindle.
could have found its way into the box and frozen......or at least made the oil super thick
Dec 6, 2011
11,601
25,455
South Wales
Coach built Adria
it aint the linkage then, as said above could be sticking clutch or gearbox oil levels / oil viscosity.
what happens if you run the engine till its up to temperature then try engaging gears.
Wildbill
Nov 18, 2011
11,862
43,069
Planet Earth
A van
Over 25 year's
so if the oil is super thick will that stop me geting the gears and it is a ducato
43,337
49,538
Certainly will Bill.
its the water in the oil which is trying to freeze and thick semi frozen oil will stop the syncro hubs and cones engaging.
as already suggested try running the engine until warm....that will also warm the gearbox and thin the partly frozen oil.
Dec 6, 2011
11,601
25,455
South Wales
Coach built Adria
its possible in these temps. as i said try running engine up to temp, then switch off ( will stop you crunching or lurching if the clutch is a problem ) and try gears then.
When the engine turns over / runs without the clutch depressed it turns the mainshaft in the gear box even if its not in gear . thats why in cold weather its good practice to dip the clutch on start up to reduce the load on the engine starter and battery.
that will agitate the gearbox oil and warm that up a bit too.
give it a go before crawling under the bonnet to check things out.
any idea how many miles / years its done on current gearbox oil?
Wildbill
Nov 18, 2011
11,862
43,069
Planet Earth
A van
Over 25 year's
i can smoothly get all gears wen engine not ruining i am ruining engine now it is up to temp but still cant get gears and think i have stretched clutch cabal with feing to have handed when i lift of clutch it wants to engage straight away i can get it in gear when engin not runing
Dec 6, 2011
11,601
25,455
South Wales
Coach built Adria
As Papajohn has said water in the oil dont help. that can get there by a number of route... through direct water getting into the box, or through condensation over a number of years. ( the oil gets warm and when it cools quickly particularly in these temps it condensates )
Wildbill
Nov 18, 2011
11,862
43,069
Planet Earth
A van
Over 25 year's
it is a1985 ducato 70'000 had its cluch changed @ 60'000 the linkig is a bit worn but has been changing ok
Dec 6, 2011
11,601
25,455
South Wales
Coach built Adria
then its the clutch or cable you need to look at.:Sad:
Dec 6, 2011
11,601
25,455
South Wales
Coach built Adria
not sure, it would normally have some basic adjustment. google or youtube might help:thumb:
43,337
49,538
Yes, there will be an adjuster...either manual or automatic.
could be many things causing it but i doubt you stretched the cable with a few pedal press,s.....that would come on gradually over thousands of miles.
more likely the clutch plate isnt fully releasing when you press the pedal.
Wildbill
Nov 18, 2011
11,862
43,069
Planet Earth
A van
Over 25 year's
the arm is only movein 1 1/2 in when cluch folly depresed
aba
2,775
1,112
yorkshire
dec 2009
if they didn't replace the cable when they fitted the new clutch the extra spring pressure of a new clutch may cause it to start breaking strands in the cable which will lead to it stretching and eventually snap.
however.....
there is normally a plastic D shaped spacer that screws onto the cable and rests in the slot on the end of the arm on the gearbox.
sometimes the steel lock nut is lost and never re-fitted which in most cases isn't a problem but sometimes the D shaped spacer will slip down the threads a little bit lowering the pedal and reducing the travel so the clutch doesn't disengage properly.
if it is a cable operated one (some were hydraulic) the adjuster will be right on top of the gearbox and should be in the form of the plastic D and a m6 thread 10mm nut on the front edge of the clutch arm.
DP+JAY
2,533
14,782
Dalbeattie
Laika 5009
If you can get all gears with engine off but NONE with engine running & the pedal feels normal then the friction plate has stuck to the flywheel. Not uncommon if its been stood for a while or if it was parked up with the clutch wet eg. after going through deep water. Best cure is to drive it in 1st gear with the clutch depessed butt with GREAT CARE. Select first gear & with the handbrake off start the engine, but be sure you havre plenty of room to manouvere.
If however the clutch pedal feels lower than normal or more spongy then it's a cable or hydraulic fault. NNot knowing year /model doesn't help the diagnosis.
Wildbill
Nov 18, 2011
11,862
43,069
Planet Earth
A van
Over 25 year's
thanks jay think i know wat wrong now cluch pedal just droped off bolt in hing just snaped:cry::ROFLMAO::cry::ROFLMAO::ROFLMAO:
