Gen - floating earth (1 Viewer)
Glynn
163
18
Lancashire
I have a small generator & if it's connected via the EHU point the reverse polarity light is on
I believe it's to do with the generator having a "floating earth " rather than a bonder neutral/earth. What does it really all mean i.e. is it OK to use in this manner for limited use as I would prefer to connect through the EHU rather than clip to the batteries for charging .
The Autotrail book says this does happen with generators but doesn't say if it's a bad thing...
43,329
49,444
bit complicated to explain....
many generators have a centre tap earth in the windings which means the earth is actually connected to the 0v position of the wave form.....ie: 120v+ on one side of the 0v and 120v- on the other side of the 0v
imagine a figure S with a centre line through the middle like so... [STRIKE] S [/STRIKE]
the centre line has no volts so the charger sees the wrong polarity 50% of the time....120v+ 0v 120v-.
normally it would see 120v+ and 120v- for each half rotation of the rotor with 120v- and 120v+ on the next half rotation, with the earth being seperate from the windings.
not really much you can do about it except possible driving in an earth spike to the ground and connecting the gennie casing to that with a thick (10mmsq) wire which may or may not do anything constructive (never had the urge to try it) but reversed polarity shouldn't cause a problem.
sorry you asked now ? :roflmto:
Jun 2, 2010
4,924
11,290
Flintshire
Low profile
since 2010
Thanks for tha papps, you're definately wasted, you should be a lecturer!!:thumb:
wivvy's dad
3,205
1,795
48.066895,12.862673
Transit LWB Hi-Top PVC
On and Off since '98
I don't get reversed polarity - I get the NO EARTH light from my plug-in polarity tester when my Honda 1k genny is patched into the EHU.
I just make sure I'm wearing my Crocs................::bigsmile:
43,329
49,444
that's because the earth in a gennie is actually connected to neutral internally.....0v
the earth in your house is also connected to neutral, but at the power/sub station, and gets back to the station via the ground
Stephen & Jeannie
4,174
3,265
Gobowen near Oswestry !!
Sold and bought a Caravan
9 years !!!!
I mentioned this to Dave Newell (the fount of all motor home knowledge !) He said not to worry it's perfectly normal !!:thumb::thumb:
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
You get the same sort of indications from a socket tester when the sockets are being run from an inverter too, if anyone is interested!::bigsmile:
ubuntu1
155
44
Derbyshire
PVC
since 2006
no earth
Its just the difference in the way a gennie is wired compared to a powerstation! There are ways around the problem and most service engineers that carry generators have a "special" hook up lead which simulates what happens in a powerstation. I'm not going to tell you how to wire it as I don't want to be responsible for electrocuting members of the site!!!!
But don't worry what your seeing is normal.
G
Glynn
163
18
Lancashire
Thanks for that folks, I will just use it via the EHU inlet then.
It's really only a just in case scenario anyway.
