Gemerator service (1 Viewer)
peter H
1,313
665
Neath, South Wales
Low profile
Nearly 4 years
Ok at the risk of kicking off the usual and highly boring debate on the merits of Red generators against Yellow generators or even Blue one......
Where, preferably in South Wales can I get my Kipor IP2000 generator serviced?
Thanks all.
Peter
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
Peter save your holidays up and have a trip to Portugal JJ is a magician with them
43,331
49,467
may be a daft question Peter, but apart from an oil change and clean/wash the air filter what else is there.....?
none adjustable electronic ignition, spark plug will be good for many hundreds of hours use and modern plugs dont like being cleaned, basic carb wont need adjusting and the electric output is none adjustable.
peter H
peter H
1,313
665
Neath, South Wales
Low profile
Nearly 4 years
Its difficult to start and when it does sometimes won't go into full speed? Sounds like a sewing machine on steroids. Oh cuts out when you swich from start to run.
Peter
Road Runner
1,143
1,445
Europe
yes
Since before Motorhomefun
Thanks all.
Peter
you have a PM
43,331
49,467
Peter
good enough reason for a service then Peter...i thought you meant a routine service :Doh:
sounds like a partly blocked main jet and not the easiest of carburettors to remove :Sad:
peter H
peter H
1,313
665
Neath, South Wales
Low profile
Nearly 4 years
Although I worked in the motor manufacturing industry for some 38 years, the workings of the internal combustion engine are and I hope always will be a complete mystery to me !
Peter
43,331
49,467
thats the problem being a production line operative Peter.....you bolt a part on but you niether know or care what it is or does :ROFLMAO:
