Gearbox change fiat ducato? (1 Viewer)
Feb 27, 2011
14,741
76,030
UK
Self Build
I am about to have my gearbox replaced. I obviously have a few questions... If anyone can provide any advice I would be grateful...
I am a fulltimer so I obviously need to plan the job. Is a gearbox replacement a job that can be done in a single day or do I need to book a B&B for overnight?
I have no idea where/what the timing belt connects to. Is replacing the timing belt at the same time likely to add much time to the job? If it adds much time I would be better leaving it to another time to avoid having the job go into 2 days if possible?
Is it worth getting the clutch plates replaced at the same time?
Any indication of how much this will cost (excluding the cost of the gearbox itself) would be appreciated. I have a gearbox sorted. I just need to save up the extra money needed?
Any other advice for me or questions I need to ask?
Thanks in advance :thumb:
Aug 27, 2009
19,792
23,071
Hertfordshire
Van Conversion
40 years
I have a question rather than an answer, what is broken in the gearbox.
43,331
49,467
providing no problems are encountered the box should be less than a day in a professional workshop.
definitely replace the clutch while the box is out unless it known to be low mileage and in good condition.
false economy not to as if it fails later the box will have to come out again, with the same cost again.
timing/cam belt is at the other end so unless they lift the engine out to do the box (unlikely) it will be extra time....easier and quicker with the engine out.
cambelt replacement is around £250 to £350 at an independent garage
Gromett
Feb 27, 2011
14,741
76,030
UK
Self Build
It is extremely noisy, it jumps out of 1st gear which is a nuisance when in traffic queues. It grinds when going from 1st to 2nd if not very careful with revs. Other than that it is fine:ROFLMAO:
I can manage with it at the moment but I want it doing before I go to the continent as recovery would be far more expensive.
I have looked at getting this one repaired but although the repair itself is cheaper than the replacement the additional costs of being without the van for 3 days puts it over. It is cheaper for me to get a replacement and only have 1 day in the garage.
I can get a recon gearbox for £550. 10 hours garage time at 45+VAT is £540. so a total of £1090. I will save up £1300 to be on the safe side. Add in £100 for a clutch kit I think...
Thanks PappaJohn, I will get the clutch redone at the same time and go in for the timing belt on another trip.:thumb:
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
if it is going to be more than a day then look for another workshop
i have removed these gearboxes within 2 hours on a trolley jack at the side of the road.
fitting the clutch kit should take no more than about 20 minutes once the box is out then its just a case of refitting it.
the only other thing that if needs replacing would be an ideal time to do would be the bottom ball joints
Gromett
Feb 27, 2011
14,741
76,030
UK
Self Build
Thanks for that:thumb:. How much time would that add onto the job?
If it is straight forward and not too expensive I may as well have it done and get it over and done with.
darklord
1,241
1,230
essex
coachbuilt
three years
Query the hours quoted, then ask why so long, we can do a Scania clutch in 4hrs, book time is only 6'ish, so why a ducato g- box should swap should take 10hrs, beats me?
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
personally if they don't need doing i wouldn't bother as they don't just fail you generally get plenty of warning of pending failure.
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
make sure the gearbox you get to replace it is the same as there are a few variants and as such they wont just swap.
things that tend to be different are the clutch arm, the driveshaft lengths, clutch plate and the mountings. so be careful to ensure it is the same.
Gromett
Feb 27, 2011
14,741
76,030
UK
Self Build
I put 10 hours to be safe. A working day is 8 hours I just added a couple to be safe:thumb:
Ok, what are the symptoms to look for on this?
Thanks, I will get the garage doing the fitting to talk to the supplier to ensure that there are no problems. :thumb:
Carol
14,051
112,114
North Wales.
Why don't you pm John (Champers) husband, JJ and many others highly recomend him, and you know you won't be ripped off.:Smile:
Gromett
Feb 27, 2011
14,741
76,030
UK
Self Build
The problem is I am tied to be near my mum for the next 3+ months and I want it done before the Summer..
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
the first sign of ball joint failure would be slight play at the bottom of the wheel whilst jacked up, after that uneven tyre wear , possible vibration and then you would start to hear clunking over bumpy roads.
if you had a sprinter based motorhome i would say get them done as they seem to eat them for some reason but unless you have any play in them leave them alone.
if the garage doing the job is worth their salt they will check them before putting the van back together but if there is a problem they should notice it when they start working on them.
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
JJ put some pictures on here when his van was in the garage and said what a great job the person did and how he recommended them [HI]see post above from Carol[/HI]
he had all his jobs done and was very pleased:thumb:
Oct 1, 2007
7,064
13,964
Kirby cross further from londin
Between Motor homes
since 08
if its any use
link to my engine probs engine out
Link Removed
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Hi Gromett, you are in the wrong place ::bigsmile:I would be looking at well under 200 quid for a gearbox and well under 200 for it fitting.
I only paid 300 quid for a complete Iveco engine and gearbox which has all ancillary starter, alternator,fuel pump,turbo the lot :winky: all I need now is a van to fit it in ::bigsmile:
Terry
Terry
11,932
9,085
Lincolnshire
Can't remember ;)
Keep it safe and you can fit it to the Wagon after another few hundred thousand kilometres...
JJ:Cool:
It's in the garage waiting for the Wagon or my AMBULANCE :winky:::bigsmile: I was very tempted a couple of weeks back by a 2007 lwb hr Iveco that needs a new engine.I think it would be a case of stright fit instead of the 2.3 engines they fit into that model/year,maybe mess with exhust but no electrics would be needed :ROFLMAO:::bigsmile:
terry
Gromett
Feb 27, 2011
14,741
76,030
UK
Self Build
:Smile: Hi just out of interest how many miles has the van done :Smile:
Just under 100,000 but it has been hammered.
Are you having it done while in Louth
what is the model of fiat ducato
I don't know where I will be getting it done. It would have to be within 50 miles of Coningsby as that is where my mum is. I need to be near her as she will be living without a hip joint for 6 weeks, then back into hospital to get a new one fitted and will be struggling for at least 4 weeks after that. I want to stay very close in case she has a fall or needs me for anything.
Terry
If I wasn't fulltiming in the van I would go cheap as chips. However I need it to be right first time. A recon gearbox with warranty from a supplier with a good reputation at £550 is a reasonable price in my view.
Thanks guys, this is all good info :thumb:
Oct 1, 2007
7,064
13,964
Between Motor homes
since 08
about 36000 miles 200 miles after a belt change
wasnt the belts fault
according to the repairing workshop
the van had overheat problems rectified earlier on in life
as found in the history that came with it
obviousley read after purchase
thats assuming you ment mine and not grommits who
wants information on changing his gearbox
:thumb::thumb::thumb:​
Gromett
Feb 27, 2011
14,741
76,030
UK
Self Build
Got another question (sorry)
Can anyone tell me where on the gearbox I can find the number?
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
sounds a good idea however when I contacted him about the escort prior to taking it to a local garge I was told he was shorthanded and virtually retired.
Gromett
Feb 27, 2011
14,741
76,030
UK
Self Build
I have just crawled under the van to look at that bit and there is a big bloody bar running side to side which blocks the view. I cannot see anyone of getting to it without putting it on ramps or jacking the bugger up....
I may have to talk to the local garage:Sad:
