GASLOW SYSTEMS Auto changover (1 Viewer)
Nov 25, 2013
1,119
1,761
kent
Swift Kontiki 669
Since April 2013
Has anyone had experience of the Auto Changeover regulator not working on the dual cylinder system
Oven and grille work ok but I believe the truma boiler needs a higher pressure to fire up. Both gauges read ok (not the magnetic types) There is no manual over ride on the valve.
Any Ideas?
Martin
Jaws
23,836
72,479
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Might just need the boiler servicing ..
have you tried filling the gas up and checking if the boiler then works ?
TerryL
6,184
8,186
North East
Low Profile
I didn't think the autochanger was related to the regulator - but I'm happy to be proved otherwise. Sounds more like the regulator is starting to fail to me.
makems
3,440
27,699
Ingleby Barwick,,Teesside
Sadly had to give up
Is the regulator by Truma?
If so I would go with Terry's diagnosis.
We had an almost identical set of symptoms a couple of years ago. The regulator was gummed up with oily residue and reducing the gas flow. Sufficient to run the hob and the fridge but not sufficient flow for the boiler.
Truma regulators are notorious for failing due to this cause.
Jaws
23,836
72,479
Thetford Norfolk
C class, Chieftain
Was this when you was in a certain place somewhat south of here by chance ? :)
MattR
4,104
38,878
Beds
Panel van
Years
Any idea how many fill ups you might get before regulators start to gum up when using refillable systems?
Jaws
23,836
72,479
Thetford Norfolk
C class, Chieftain
A while later I replaced my unit with a 'normal' regulator.. I seem to remember you ended up replacing like for like and having to get it from Portugal ?
TerryL
6,184
8,186
North East
Low Profile
Some people have had it happen a couple of times in a short period, others (like me - so far!) have never had it happen. Despite all sorts of theories that have been expounded on here, there doesn't seem to be a cast iron answer.
I carry a spare!
MattR
4,104
38,878
Beds
Panel van
Years
I was about to buy an automatic change over valve with the regulator built in (£48). I am wondering if it would be more economical to buy two separate items (total of £60) as the regulator is only a few pounds to replace in the future.
Jaws
23,836
72,479
Thetford Norfolk
C class, Chieftain
That is what I would do ! The auto changover bits never seem to cause any grief ( at least none I know of ) but the regulators are for ever gumming up !
TerryL
6,184
8,186
North East
Low Profile
Have to say I wonder if an automatic changeover valve is really worth it? Given the inaccuracy of the gauges I'm far happier just running on one bottle then when it runs out changing it over manually and start planning a refill. That way I never unknowingly run out of gas.
I haven't bothered with a manual changeover either, just shut one bottle off and open the other. K.I.S.S.
makems
3,440
27,699
I got it replaced in Portugal but not with a Truma - I got a Clesse as Tommy at Camperserv was out of stock of Trumas - there had been so many failing.
Strangely the Clesse failed just under a year later and Tommy replaced it under warranty. Different issue though, the Clesse was just leaking from somewhere.
sleep e carr
109
31
Whitby North Yorkshire
Talbot Express 6 birth
Since 1970 first van converted police van
I have had my van for 3 months and had change over valve for half of that but have had no trouble with it at all,
I bought it from a firm in Bangor northern Ireland my fitter from KDR Leisure Scarborough fitted it when he came to do my elec and gas check, I find it some much easier than struggling with bottles, I have had pig tails fitted, one goe's to blue, and one to red bottle just turn the tap and your back on, as long as it takes to unlock the gas cupboard and turn the tap, mine was £45 delivered hope this helps
TheBig1
17,630
43,277
have had a few truma regulators gum up and fail, but never a cleese or a gas-it, both of them cheaper than the truma
Jaws
23,836
72,479
Thetford Norfolk
C class, Chieftain
Its odd really.. makes me wonder what is in the Truma ones that make em fail as often as they do.
Would not be so bad if they were sensibly priced.. Might be they are saving the jets in the various appliances getting gummed up.. but at about £40+ a go every two years I think I will take my chances with a cheaper option !
MattR
4,104
38,878
Beds
Panel van
Years
Having installed 2 x full 6kg bottles, I filled them after a fortnight of use with BP lpg (approx £12). This afternoon, I noticed some brown oily liquid seeping from the fill point hose. I'll tighten the hose tomorrow but was staggered that so much oil was present after one filling (it is too late to tell how much exactly but I'm guessing at least half a teaspoon). Is this likely to have been an isolated contaminated supply or is this degree of contamination normal?
Sep 9, 2011
1,010
6,767
Worcester
looking
Can anyone tell me when you fill up in the UK do you use the UK adaptor or just put the nozzle in lock it on and then push button,sorry to be pain first time filling up today cheers to everyone
Dec 24, 2009
1,072
15,719
bedworth warks
c class
2009 previously a tugger for thirty years
In the UK you just put the nozzle on and lock it. Assuming you have a standard UK fitment you will only need adaptors abroad.
D
Deleted member 29692
The Gaslow filler is UK standard so you don't need any adapters. Lock it on, press and hold the button in until it's finished filling. Don't let go of the button or it stops.
Minxy
32,651
66,541
E Yorks
Carthago Compactline
When doing your first fill you might not get in as much as you expect - this is quite normal so don't be alarmed - subsequent fills should be fine.
Sep 9, 2011
1,010
6,767
Worcester
looking
Hi thanks to everyone who write about everything on here I certainly get my moneys worth its the best forum for help and advice,just done my first fill on my gasit bottles worry I certainly did but no problem at all (y)(y)(y)
Thankyou
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
I believe the "Gumming up" is caused by the pigtail dissolving, change them to stainless steel ones before you have a problem. Of course I could be entirely wrong and that could be a different problem entirely.
Minxy
32,651
66,541
E Yorks
We've had a refillable system since 2009 and have to date put in 290 litres (costing £177 av cost of LPG 61p per litre). We have had the same kit (minus regulator) in 4 vehicles, the 4th only having it installed a few weeks ago as we've changed vans, in all that time we have never ever had a problem but we did get stainless steel filler and connection pipes, they aren't cheap but don't need to be changed every few of years or so and I'm happier with them being 'tougher' than just plain rubber gas pipe.
