Gas problem (2 Viewers)
Jun 13, 2013
12
8
Kenilworth
A class Burstner
We are in Spain at the moment using Spainish gas butane,it runs ok all day then between 2-3 am goes off and the alarm comes on,we put back on gas in the morning and it runs fine ,the outside temp has not dropped below 10c,the fridge was cleaned just before we left the UK any suggestions.
Hymerm60
10
4
Kent
caravan 30+yrs 1st yr motorhome
Had a similiar problem a few years back, during day all worked ok on gas, then as has happened to you, about 2am fridge alarm goes off, you have probably got a gas regulator that is "sticking" and it takes a few hours with little use of gas for it to eventually close and stick shut until you give it a kick in the morning, we changed the reg and all was ok.
g8ysn
638
417
ng219ep
suprising what a sharp tap with a hammer doe,s,
Badknee
7,408
412,991
notloB
Vantage Neo
Living the dream.
Yes, give it a tap or a ride to the tip :D
Badknee
7,408
412,991
notloB
Vantage Neo
Living the dream.
We just had our MoHo back in for some snagging to be done and one was the fridge wouldn't run on gas. It turns out to be the "12volt/230volt/gas switch that wasn't allowing it to run on gas.
Sailerpete
Jun 13, 2013
12
8
Kenilworth
A class Burstner
All fixed now cleaned out jet with a small wire put thermal heat element closer to the flame, runs a treat.
